Username Post: Carb. Rebuild        (Topic#367037)
DucatiRod
Loc: Maine
Reg: 12-31-20
11-24-21 11:58 AM - Post#2831401
Question to settle discussion: What is the right thing to put on a Carb Bowl Cover gasket when rebuilding; White grease, oil, Indian Head, or maybe nothing, or what?
Thanks in advance~
Edited by DucatiRod on 11-24-21 12:56 PM. Reason for edit: add word
11-24-21 01:43 PM - Post#2831403
    In response to DucatiRod
Never used anything over many years.
Member #409
11-24-21 07:50 PM - Post#2831416
Not only have I never used anything on carb gaskets, I've never heard of others doing it either.
DucatiRod
Loc: Maine
Reg: 12-31-20
11-25-21 05:40 AM - Post#2831422
    In response to Rick_L
Thanks for the replies, I never saw anything making gaskets stick when taking a carb apart, but needed some more input~
carbking
carbking
Loc: Missouri
Reg: 06-14-03
11-25-21 05:58 AM - Post#2831423
Late to this thread, but as others have posted; absolutely nothing!
Jon
Good carburetion is fuelish hot air!
The most expensive carburetor you will ever buy.....is the incorrect one you attempt to modify!
If you truly believe "one size fits all", trying walking a mile in your spouse's shoes!
Mercedes
Reg: 07-09-18
11-25-21 06:32 AM - Post#2831426
There is no need to put anything on the gaskets.
paulo57509
Loc: CA
Reg: 07-18-00
11-26-21 05:00 PM - Post#2831464
Thanks in advance~
I've never used anything on any carb gaskets.
However, years ago I read someplace to use a little Chap-Stick on Holley metering block/bowl gaskets. This was in regards to saving gaskets when having to do jet changes when tuning.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 11-26-21 08:48 PM. Reason for edit: Spelling
DucatiRod
Loc: Maine
Reg: 12-31-20
11-27-21 04:50 AM - Post#2831484
    In response to paulo57509
  • paulo57509 Said:
Thanks in advance~
This sounds something like I was thinking when I mentioned "oil" in the original post. Back in about 1970 I had an early 50s H.D. when I got a gasket kit for it, enclosed was a paper saying to soak them in oil over night before using~
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
11-28-21 05:29 AM - Post#2831510
....and all those years we thought HDs just leaked, guess it was the oil from assembly being squeezed out of the gaskets !
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
Execution time: 0.243 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:20 PM
