Danchuk
Username Post: Replacing Kickdown Cable        (Topic#367028)
carolinakid
carolinakid
Loc: Erwin NC
Reg: 08-27-03
11-23-21 01:56 PM - Post#2831338
Have TH350 Transmission in my 56. Kick down cable casing has developed a crack and is leaking Trans Fluid. Can Cable be replace with out dropping transmission? Believe the cable has a hock on it and hooks on to something in transmission. Was wondering if dropping the pan would help attaching it internally. Thanks
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
11-24-21 04:15 AM - Post#2831370
    In response to carolinakid
You definitely should not have to drop the transmission. It's been a few years but as I remember, if the linkage is still sticking up out of the hole where the cable bolts then you can just hook the new kickdown cable to it but if the linkage has fallen down into the pan it may require removing the pan.
Vern
1930 DeSoto Business Coupe- 350 Chevy V8, EFI, 4-wheel disc brakes, Wire Wheels, TH400, S-10 Rear, A/C
carolinakid
carolinakid
Loc: Erwin NC
Reg: 08-27-03
11-24-21 10:02 AM - Post#2831393
Thank you much, memory refreshed!
Execution time: 0.17 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:45 PM
