Username Post: oil pan removal        (Topic#367024)
Airlifter
Airlifter
Reg: 06-07-15
11-23-21 06:55 AM - Post#2831318
I spent yesterday removing the oil pan on the 261 engine. Sounds simple right? Loosen the motor mounts, jack up the engine and remove pan. Wrong. The bell housing is almost touching the floor board and the engine would not move. You would think that with the engine this high the oil pan would come out. Wrong again. I finally had to unhook the tie rods and swing the idler arm out of the way and it was still hard to get off. I might have to remove the engine to get the oil pan back on.
I had posted before about this engine sitting higher than the 235 but could not fine the reason. I bought another set of motor mounts on the chance that the first set were wrong. I had removed the oil pan on the 235 when it was in the car. I still can't figure out the difference.
Thanks. Just wanted to rant
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
11-24-21 07:59 AM - Post#2831384
    In response to Airlifter
If the new motormounts are too short, it will end up raising the engine. When I made my first set of motormounts, they were too short, and I couldn't even get the valve cover off--the top was hitting the cowl. Back to the drawing board, and I made a second set that has worked well.
Airlifter
Airlifter
Reg: 06-07-15
11-24-21 10:45 AM - Post#2831398
I ordered two sets of mounts from two different vendors and they are exactly the same. I am going to modify one set to lower the engine about 1/2 inch. That still doesn't help the problem of getting the oil pan off.
I thought that maybe the oil pan was larger on the 261 but, if I understand the parts manual, they have the same number.
Thanks for the response
11-24-21 05:39 PM - Post#2831414
Here is a discussion about the oil pan on a 235. Gene Schieder tells how to install the pan.
https://vccachat.org/ubbthreads.php/topics/152001/...
29-41, 42-48, 49-54 Moderator
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-26-21 07:06 PM - Post#2831467
The 261 oil pan is a different shape than the original 235 so it will be necessary to experiment.
Airlifter
Airlifter
Reg: 06-07-15
11-28-21 04:55 AM - Post#2831507
    In response to Gene_Schneider
Thanks for all the information. Will the 235 pan work on the 261 Will the oil pump piping interfere?
Execution time: 0.166 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:22 PM
