Username Post: remove dust in clearcoat        (Topic#367018)
995jim
"5th Year" Platinum Supporting Member
995jim
Loc: Ohio
Reg: 12-17-06
11-22-21 03:25 PM - Post#2831289
Hello, Ihave some dust inbedded in a new clearcoat application. what is the standard formula to remove ?
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
Mercedes
Reg: 07-09-18
11-23-21 01:27 PM - Post#2831333
    In response to 995jim
There is no way to remove it other than wet sanding and buffing. If the dust is all the way through the clearcoat, then you have a real mess.
How much dust are we talking? The occasional nub or all over?
995jim
995jim
Loc: Ohio
Reg: 12-17-06
11-23-21 03:14 PM - Post#2831345
    In response to Mercedes
its not all the way through, I guess i would consider it minor but I wanted to try polishing it out. I have a variable speed buffer but dont know what combination of pad(fine, med, hvy cut, foam )and what grade of compound is to be used with each pad since you can get a wide range of each item mentioned. If I were to wet sand do I start with a 2000 grit or go higher . Ive even heard of people using comet cleaning powder to as an abrasive.
Mercedes
Reg: 07-09-18
11-23-21 05:31 PM - Post#2831357
Start with wet/dry 2000 grit and use a flat rubber pad so that you don't end up making finger depressions as you sand the clearcoat. Use lots of water and add a small amount of dishwashing soap so that it slides better.
Wet sanding makes the surface flat so that the buffer can make it glossy.
Use caution and stay away from body lines as you can end up sanding right through.
Site Ambassador
11-28-21 10:06 AM - Post#2831520
2000 wet sand will work fine if it’s minor. You don’t necessarily need a pad if you sand in small circles and it’s a small area. You don’t need the soap if doing very small areas unless you want to. Just make sure either way to flush the sanded areas clean with clean water so all sanding residue (and soap) is gone. For buffing you can start with a rubbing compound and a wool pad. Then go to a finer polishing compound and a foam pad. Then switch to another foam pad and use a finishing compound. As stated, be careful around body lines and panel edges. The paint is thinner in those areas.
1957 Cameo Carrier
Execution time: 0.316 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:57 PM
