Username Post: 1965 impala tilt column        (Topic#367016)
grechevy
grechevy
Loc: delaware
Reg: 01-25-09
11-22-21 01:49 PM - Post#2831283
have chance to a tilt column for my impala.will my factory non tilt wheel and bottom column dash cover work.
mjc1
mjc1
Loc: Burlington Ontario Canada
Reg: 09-15-04
11-23-21 01:29 PM - Post#2831334
    In response to grechevy
The wheels are certainly the same.
But I believe the covers have different lengths between the two.
1965 Laurentian post, 1967 Grande Parisienne 4DR HT
My Flickr page
bigred65
bigred65
Loc: Kenmore WA
Reg: 03-18-13
11-23-21 08:34 PM - Post#2831368
    In response to mjc1
The wheel is the same. You need to make sure the dash collars are with the column, as they are shorter than the standard column. You also need to make sure that the piece that bolts to the rag joint is there, as the tilt and tilt tele have a removable end. They are also really hard to find separately, the wire harness adapter you can buy after market, you also want to make sure the cable for the turn signal switch is free and working as well as the turn signal switch is there as well. Good luck
Brandon.
1965 Impala SS 396 4spd
1966 Impala SS convert 4spd
1973 Corvette 4spd
1973 Firebird Formula 4spd
1959 Corvette FI 4spd will restore it someday!!!
grechevy
grechevy
Loc: delaware
Reg: 01-25-09
11-24-21 08:17 AM - Post#2831388
    In response to bigred65
thanks big red.i am going to pass on this column.was looking cause on my 1967 ss chevelle i did same swap and was a simple bolt in everything including plug was same thanks
Oshawa65SS
Loc: Grande Prairie AB & N...
Reg: 09-22-14
11-24-21 06:57 PM - Post#2831415
Thanks to Tony the info I referred to previously is once again available so here it is in case you reconsider:
http://toms427impala.info/CT/65-66CollarsFullS ize....
http://toms427impala.info/CT/65-66ColumnCollar s.pd...
Ryan
Build date Dec. 21 '64 Oshawa
grechevy
grechevy
Loc: delaware
Reg: 01-25-09
11-25-21 05:59 AM - Post#2831424
    In response to Oshawa65SS
amazeing amount of info on this site.thank everyone for info.
Execution time: 0.196 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:29 PM
