Username Post: Starter Wiring        (Topic#367004)
yyz-impala
Loc: Toronto
Reg: 11-20-21
11-20-21 08:23 AM - Post#2831163
Hello,
The would be my first post (Hello Everyone) and hope l have come to the right place full of advice and knowledge.
I inherited my Grandfather's 71 Impala Convertible which l put into dry storage for the last 7 years until l had room and time to work on it.
With that said, the vehicle is now home with a fresh battery, new fuel, pulled the plugs and oiled the cylinders. Now my question, the starter does not seem to make any noise at all.
There is power from the battery, power in the on position, l heard a relay click upon start position but nothing at all from the starter.
I wonder if anyone might have a wiring diagram so l can find the source/trigger wiring under the hood?
Thank you in advanced.
Mercedes
Reg: 07-09-18
11-20-21 11:01 AM - Post#2831176
    In response to yyz-impala
Check for power at the starter solenoid when you turn the key to "start". Keep in mind that in that vehicle, having the gear selector in any position but P and N it will not crank the engine.
If the neutral safety switch is not aligned properly or not working, you'll have the same issue.
Check for power.
yyz-impala
Loc: Toronto
Reg: 11-20-21
11-20-21 01:35 PM - Post#2831190
    In response to Mercedes
Mercedes thank you for the reply. Do you know where l can find the source/trigger wire for the solenoid and where l can find it under the hood?
Mercedes
Reg: 07-09-18
11-21-21 05:09 AM - Post#2831219
The power wire connected to the solenoid terminal is where you would pick up the voltage signal. If you need the wiring diagram, you can go to Alldatadiy.com and get the full thing.
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
11-21-21 07:05 AM - Post#2831223
this might help ...
My first car: 1970 Olds, 442,455
My last car : 1966 Chev. Impala convertible,396
current car: Can't afford them anymore ...
yyz-impala
Loc: Toronto
Reg: 11-20-21
11-21-21 03:30 PM - Post#2831244
    In response to space66
Thank you very much for the wiring diagram. It was helpful enough for me to diagnois the safety neutrual switch faulty.
The vehicle now runs..
Mercedes
Reg: 07-09-18
11-23-21 04:07 AM - Post#2831312
Glad you fixed it! The lack of any power at the starter solenoid is a signal that the ignition switch or neutral safety switch are at fault.
Execution time: 0.164 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:49 PM
