B_Man
Reg: 03-02-10
11-19-21 07:25 AM - Post#2831112
Hello everyone. I have a 70 z28 intake manifold and cam. I would like to build a 350 sb Chevy with 450 hp and use that intake and cam. Can it be done and if so, does anyone know what heads, crankshaft and carburetor I should use. I would sure appreciate some help and thanks.
grumpyvette
Performance Subject Matter Expert --
Loc: farmersville texas USA
Reg: 03-16-01
11-19-21 10:22 AM - Post#2831122
In response to B_Man
https://www.youtube.com/watch?v=qk5NGwqEweE
https://www.youtube.com/watch?v=HmriKtQ2SJ0
the cams not ideal, watch the videos
IF YOU CAN , YOU NEED BETTER TIRES AND YOUR SUSPENSION NEEDS MORE WORK!! |
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
11-20-21 11:08 AM - Post#2831177
I've often wondered if these horsepower claims are valid. I can't imagine there is some "magic intake" that will raise the horsepower that much let alone a cam that will.
I'm saying this because a modern V8 engine with variable valve timing and 32 valves has a hard time coming up with 450 horsepower.
People fear change because it threatens what they know, or what they claim to know. |
B_Man
Reg: 03-02-10
11-24-21 06:15 AM - Post#2831374
In response to grumpyvette
B_Man
Reg: 03-02-10
11-24-21 06:16 AM - Post#2831375
In response to Tony1963
Thanks, that was very enlightening.
