Username Post: Turn signal issue.... Running out of hair to pull out        (Topic#366936)
LD-Ordie
Loc: Upper Mojave Desert in Ka...
Reg: 10-31-21
11-13-21 03:24 PM - Post#2830758
I have a new to me 67 Chevelle SS, trying to work the bugs out of it. So left turn is fine, right signal appears to have a ground problem? Power going to the switch is 12 volts, stays that way for left but goes super dim for right. Not enough to activate the flasher, Everywhere I check in the circuit is weak. If it is left on while driving, it starts to works sometimes.........so something is loose somewhere. I installed a new switch by plugging into the harness outside the column, same results. Grasping at straws here, is there an area someone can suggest I look? Wiring in general looks clean and un-molested, no weird mods, rust, etc Wiring is not my strongest area Thanks in advance
Proud current owner of a 67 Chevelle SS 396, 55 Chevy 3100, 327 4spd, 39 Ford P-Cup, 327 350 Turbo, 52 Chevy, Styline Deluxe, 235, 59 Triumph TR3, 64 Land Rover Series IIA, 55 Ford, Sedan Delivery, 292 5 spd. I spend a lot of time in the shop
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
11-13-21 05:06 PM - Post#2830764
    In response to LD-Ordie
are all your parking lights, brake lights working front and rear ? bulbs are good , the flasher is good ?
power is coming from your switch , check the
harness connectors ...
check the light sockets, they're the ones grounded to the body , ...
My first car: 1970 Olds, 442,455
My last car : 1966 Chev. Impala convertible,396
current car: Can't afford them anymore ...
LD-Ordie
Reg: 10-31-21
11-13-21 05:30 PM - Post#2830765
    In response to space66
Should have mentioned parking lights, flashers, brakes all work
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
11-13-21 05:58 PM - Post#2830767
when you say the right signal , it's front (dark blue) and back (green) turn signals ? you have the wiring diagram ? follow the wires from the bulbs to switch to see where it could miss , test 12v to it to see ? if all is working, i would assume the problem lays at the harness connector to switch , but dont want to make an A$$ of U and ME...lol
Mercedes
Loc: Orlando Florida
Reg: 07-09-18
11-13-21 07:44 PM - Post#2830776
This will all be about powers and grounds. My guess would be that you have a partial short to ground where the voltage is being drawn off.
You are going to have to check the wiring with a volt meter at every connection until you find the section of wire that is compromised.
All that that circuit does is complete a circuit and the flasher interrupts the circuit.
If you jumper out the flasher, does it get bright or does it blow the fuse?
LD-Ordie
Reg: 10-31-21
11-13-21 08:04 PM - Post#2830779
    In response to Mercedes
Have not tried that yet, so tomorrow is a new day, will try then, thanks for the new insight
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
11-14-21 01:40 PM - Post#2830828
it's not a random wire short, same side signal front and back
try moving slightly the lever position, or the steering wheel, might be a bad position contact with in the switch .. even new switches can be defective as you said you tried one.
test the 2 signal wires at the harness to switch connectors from either side, to see at what side the short is if any . some times the pins pull out at the plug , but the probability that only those 2 is pretty low.
Edited by space66 on 11-14-21 04:11 PM. Reason for edit: No reason given.
LD-Ordie
Reg: 10-31-21
11-15-21 05:08 AM - Post#2830867
Figured it out! Pulled the last couple of feet of wiring from the front dead signal and noticed a section of tape that was newer. removing revealed a repair using a connector with a weak crimp, the ground side, thus the intermittent working especially at hi speed and vibration. Some of these crimpers that kinda smash the connectors are worthless in my opinion. Just hoping the same dude performed minimal repairs. I did go ahead and installed a new switch, nice that the canceling is now working. Thanks to those who responded to my cries for help. Cheers!!
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
11-15-21 07:02 AM - Post#2830875
Mercedes
Reg: 07-09-18
11-15-21 06:04 PM - Post#2830909
Interesting how many times those crimp connectors fail. They are fine for a year or two after you do them, then weather sets in and corrosion starts. Heat and vibration take their toll then poof, they fail.
Soldering is the way to go but takes more time.
LD-Ordie
Reg: 10-31-21
11-20-21 08:11 AM - Post#2831162
Cannot argue that soldering with shrink tubing is better, and some applications, I take the extra time. But I have also had great long time results with crimp type connectors when using my Klien crimpers. They do don't rely on squishing the connector, but instead, put's a deep divot in the connector. Nearly impossible to come loose.
12-19-21 07:33 PM - Post#2832909
you are using the non insul jaw of the crimper as i do. at that point the wire just about cant come out if you use the correct terminal size. black tape or shrink tube over that or shrink tube terminals that get speared from the tooth in the jaw, will make a good vibration strain relief to help the connection live longer. connections exposed to the weather will eventualy fail if not weatherprooofed. hot glue makes a real good but messy weatherproofing.
LD-Ordie
Reg: 10-31-21
12-20-21 07:03 AM - Post#2832930
    In response to bobb
Can't post a picture, but here's a link to the crimper I usehttps://www.amazon.com/Non-Insulated-Termina ls-...
Execution time: 0.624 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:24 AM
