Username Post: T-Tops and Hard Top Structural Differences        (Topic#366907)
damnyankee36
damnyankee36
Reg: 04-16-03
11-09-21 02:47 PM - Post#2830523
I'm at a bit of a conundrum. My wife loves the 70-73 models. She also loves T-tops.
Soooo, do I find a 78 and up and convert it to a 70-73 or find a 70-73 and graft in a T-top roof?
I am well aware of the difficulty of a late to early conversion as far the rear body is concerned although I am not gonna worry about installing the small rear window. I also don't plan on converting the interior.
I am wondering what the structural reinforcements are on a T-top car. If it's just the roof that's reinforced that might be a plus if I can find a T-top roof donor.
I'm not interested in discussing why I would "ruin" a perfectly good car to do this I just would like to get educated on what my options are and what I am up against. Once I get this preliminary research done I can decide if I even want to consider this project. If I can talk her into a non T-top car, problem solved!
Thanks!
Larry
Site Ambassador
11-10-21 09:58 AM - Post#2830573
    In response to damnyankee36
I am no expert by any means but I can tell you what I believe. First off, Gearz is doing this very conversion with a later model T-top Camaro, so check it out. Secondly, I don’t believe there is any added structure to a T-top car that you wouldn’t be adding anyway by grafting on a T-top roof to a non T-top car. The only other structure that might be different that I can think of would be maybe the T-top cars had different inner rockers or an additional brace between the out and inner rockers. But I am doubting that considering the way these cars twist, especially with no tops in place. If you ever watched Smokey and the Bandit there is a scene near the end where he makes u-turn through a median and when the driver turns, the rear wheel actually leaves the ground the car twists so much.
1957 Cameo Carrier
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
11-10-21 01:13 PM - Post#2830580
I am no expert here either, but from what I can remember, the roof panels are double-walled with an inner structural piece. When the T tops are cut in, there is a frame welded in that holds the seals in place that effectively bonds the two panels.
That's probably the extent of the structural integrity.
My recommendation is to go to a supplier who rebuilds T top panels and ask how those roof panels are reinforced differently. I'm guessing that the framework that I'm referring to is the extent of it.
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
11-15-21 12:40 PM - Post#2830890
    In response to Tony1963
All 1976-1981 Firebird and Camaros started out as coupes and the T-tops were cut in. But I'm pretty sure no welding was involved due to the T-tops being install after the car was painted.
I'm helping to restore a 1976 Trans Am 50th Anniversary LE with Hurst Hatch T-tops. For the Hurst Hatches, there is a metal U-shaped piece that is pinched between the inner and outer structure. about ¾" wide by eighth inch thick. This piece is not welded to the car. No other structural changes were made to the car.
Fisher T-tops are different and I do not know much about those, except I understand they had better latches.
You could gather all of the parts and have the T-tops installed on your existing roof. I think I'd prefer the Fisher T-Tops
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
    1965 Chevrolet Malibu 4D Wagon
Edited by BigDogSS on 11-15-21 12:56 PM. Reason for edit: No reason given.
Tony1963
Reg: 07-09-18
11-17-21 02:05 AM - Post#2830964
    In response to BigDogSS
Yeah, good point about the non-welding.
Execution time: 0.336 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:58 AM
