Username Post: 1962 powerglide        (Topic#366900)
robertljr
Reg: 01-04-14
11-08-21 08:37 PM - Post#2830484
Does the 62 iron and aluminum powerglide transmissions have the same vacumn modulators? I have viewed several and the screw in end seems to be different sizes on them. (i don't know which i have)and have viewed more than two different modulators. thanks in advance for any suggestions and help. Bob
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
11-09-21 04:44 AM - Post#2830493
    In response to robertljr
The aftermarket parts catalog shows that both are the same part number. Both have an adjustable screw in the end. Years ago they may have been different part numbers.
Keep in mind that these are totally different design transmission. The aluminum version was offered on the 327 engine, the iron one on the 283 and inline 6.
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
11-09-21 08:52 AM - Post#2830502
    In response to Tony1963
Caution: the 62 and early 63 aluminum Powerglide have a different modulator than the later cars . The later Powerglide modulators will not fit. The early modulator is more difficult to find.
robertljr
Reg: 01-04-14
11-09-21 11:42 AM - Post#2830507
Thanks Mercedes for your reply.I have a 327 and have been told that the year model determined the modulator.Now i find from you i might be able to specify which type i need. it seems the screw end is the difference on the used ones i have seen (nos) Can you tell me about the parts book you use and mention in your reply? Thanks a lot. Bob
robertljr
Reg: 01-04-14
11-09-21 11:46 AM - Post#2830508
    In response to dgstarr
dgstarr thanks for your reply to Mercedes in regard to my 62 327 modulator search Bob
Tony1963
Reg: 07-09-18
11-09-21 11:54 AM - Post#2830509
I logged into Rock Auto to see parts for 1962 automatics, cast iron vs aluminum (62 327 vs 62 283).
Later model year Powerglide use a different modulator according to Rock Auto.
robertljr
Reg: 01-04-14
11-09-21 12:11 PM - Post#2830512
Thanks Bob
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
11-09-21 03:33 PM - Post#2830522
I've attached screen shot from the '62 Shop Manual. It depicts the vacuum modulator installation but does not give a part number. Perhaps that is helpful.
That Manual also states the 327 was the only engine to 'get' the new (then) aluminum power glide.
Pete
Attachment: _62_vacuum_modulator.png (65.72 KB) 75 View(s)
robertljr
Reg: 01-04-14
11-09-21 04:13 PM - Post#2830526
    In response to japete92
Thanks i have wondered if i had the aluminum just thinking the 63 probably got it.Should be a lot less weight. i do have the 327 which one advisor told me today got it in 62 327 only.i found a modulator today that has red numbering on it and is adjustable for shift speed. No fitment given. Not on this sight as a seller here would tell you what it fits. new item large company.
robertljr
Reg: 01-04-14
11-09-21 04:27 PM - Post#2830528
Thanks Pete I have not seen the actual valve in your photo just the modulator part in the left hand in the picture. Is that valve an extra item to purchase also? Thanks
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
11-09-21 05:41 PM - Post#2830536
58-62 accept 327 (IRON PG) 3745169
62 327, 63 w/alum pg, 1st design 3812741
63 pg 2nd design and later years 5638205
All of the adjustable modulators I have seen were the later design. The later modulators will not fit the early alum PG because the actual valve is of a different diameter. Some after market catalogs show all alum pg modulators are the same, they are wrong!
Edited by dgstarr on 11-09-21 05:44 PM. Reason for edit: No reason given.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
11-09-21 05:51 PM - Post#2830537
I know very little about auto transmissions (on purpose; I'm into manual ones) but:
An 'extra item'? I would say required; if you don't have one.
I highly recommend you acquire the 3 most important (in my opinion) manuals for your car. The full size car versions of the 1962 Assembly Manual; the 1962 Shop Manual (Supplement); and the 1961 Shop Manual. The '62 Shop Manual only has the 'supplemental' info to the '61 Manual. 'Supplemental' meaning only the stuff that has changed from '61 to '62.
They are not expensive and are the best source of reliable data for your car.
The link provides some useful info too:
https://www.gmheritagecenter.com/docs/gm-heritage-...
Pete
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
11-09-21 05:55 PM - Post#2830538
Pete
robertljr
Reg: 01-04-14
11-09-21 06:51 PM - Post#2830546
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
11-10-21 09:09 PM - Post#2830601
Fatsco Transmission Parts has both the early and late modulators for the aluminum PG in their online catalog. Early is part # M-55 and late is 58-MT
fatsco.net is their web sight.
Eddy_Finn
Eddy_Finn
Loc: Finland
Reg: 07-19-21
12-06-21 11:21 PM - Post#2832066
What is the easiest way to indentify iron/aluminum PG on '62?
Tony1963
Reg: 07-09-18
12-07-21 01:50 AM - Post#2832069
    In response to Eddy_Finn
If it is behind a 283 or I6 it is likely a cast iron unit. Behind 327, aluminum.
Also, does a magnet stick to the case or not?
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
12-07-21 03:11 AM - Post#2832070
The cast iron glide has a cast iron spacer between the transmission and the block plus the starter mounts to the spacer. The aluminum glide mounts directly to the block and has no starter mount.
Member #2194
Tony1963
Reg: 07-09-18
12-07-21 03:28 AM - Post#2832071
    In response to DonSSDD
Thanks. I remember years back when I did my first 62 we bought an old parts car 4 door to use common parts. That old thing had a funny looking transmission. Looking back it was an old cast iron Powerglide.
Never really paid attention to those much. Must have weighed quite a bit, too.
Execution time: 0.08 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:24 AM
