Username Post: Leaking Wheel Cylinder Bleeder Valves        (Topic#366759)
SandDabMcSkeg
Loc: Coos Bay, Oregon
Reg: 01-04-18
10-20-21 10:21 AM - Post#2829532
I had Apple Hydraulics re-bore and sleeve my Delco wheel cylinders for my 46 Fleetmaster, I installed rebuild kits, and new bleeder valves from Chevs of The 40's. The bleeder valves leaked fluid slightly, so I re-installed the original bleeders, they don't leak as bad but do leak. Something has happened to the bleeder valve seats? That is where they seal, the base or "seat". Do not recommend thread sealer because they don't seal that way. The fluid is coming out the hole in the bleeder past the seats. Has anyone had experience in stopping this problem? In 50 years I have never had bleeders not seal, but I have never re-bored cylinders before either, I always used new ones but wanted to stay away from Chinese stuff so opted for re-boring my Delcos. Anyone ever solve this problem before?
10-20-21 01:46 PM - Post#2829539
    In response to SandDabMcSkeg
Possible they were sand blasted during the upgrade. If so the slightest grit in the bleeder seat can cause this.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
10-28-21 03:29 PM - Post#2829891
These wheel cylinders leak just like a valve fails to seal. There is an uneven surface for sealing and the ball seat on the bleeder screw is not totally sealing off the fluid path.
Fixing it? With enough time and money you can fix anything. I'd throw them away and get replacements.
Life is too short.
TAT_2
Site Ambassador - Member #26 - "22st Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
11-09-21 06:20 PM - Post#2830541
http://www.russellperformance.com/mc/speed-bleeder...
THAT MAY WORK.
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANNIV- RUBY RED- LT1/6-SPD/RAG TOP
QUOTE FROM HELEN
Execution time: 0.126 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:09 PM
