Username Post: Bolt threads - assembly        (Topic#366727)
FIVE-6
Reg: 05-16-16
10-17-21 07:01 AM - Post#2829338
What do you use on bolt threads for a water pump, thermostat housing, fan, ac & ps brackets, temp & oil sensors, etc. I've heard blue locktite, anti-seize, sealant, grease, and nothing at all. Some of the bolts are going into aluminum intake.
grumpyvette
Performance Subject Matter Expert --
grumpyvette
Loc: farmersville texas USA
Reg: 03-16-01
10-17-21 03:13 PM - Post#2829362
    In response to FIVE-6
http://www.grumpysperformance.com/antiseize.jpg
generally anti seize
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
10-17-21 03:34 PM - Post#2829364
It depends on whether you need to seal for coolant/oil or not. If not, then anti-seize.
10-17-21 05:45 PM - Post#2829374
for me, different app different paste. if its in water , thread sealant. exhaust, anti sieze. aluminum, blue loctite. better not come loose, red loctite.
Execution time: 0.375 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:14 AM
