Username Post: Torque Tube question        (Topic#366697)
MotorCity57
MotorCity57
Loc: Troy, Michigan
Reg: 06-08-05
10-14-21 08:08 AM - Post#2829143
I need some help with the torque tube on my 54 BelAir convertible with powerglide transmission. I've had my mechanic working on the drive train, including a rebuild of the powerglide, which was done by a local transmission shop. Now, he is having trouble re-assembling the torque tube - there is a gap where the torque tube meets the ball seal (see photos). He installed the recommended 2 shims - adding more shims would only worsen the problem. Any idea why we have this gap? Could there be something missing from the transmission rebuild?
Thanks in advance,
John W.
Attachment: IMG_0431.jpeg (354.64 KB) 2 View(s)
Attachment: IMG_0430.jpg (192.4 KB) 1 View(s)
1957 Chevy 210 Station Wagon
1947 Chevy Stylemaster Coupe
1954 Chevy BelAir Convertible
arkansas
Loc: arkansas
Reg: 09-26-06
10-14-21 10:37 AM - Post#2829153
    In response to MotorCity57
I think there is supposed to be a cork seal in there. I could be misremembering though.
1949 Deluxe Coupe 400sbc, 700r4, 3.73 posi
1949 4 door Fleetline Special, all original
1949 2 door Fleetline Deluxe rustbucket parts
1971 Chevy 1/2 ton shortwheel base, 250 I6, 2004r, underconstruction
1926 Ford T bucket, 250 Chevy, T350 tranny
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
10-14-21 11:41 AM - Post#2829155
    In response to arkansas
You are correct sir, needs a cork seal,
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
eplantage
Loc: Southern MN
Reg: 03-15-04
10-14-21 12:27 PM - Post#2829161
    In response to 2D51STYDLX
https://www.nationalchevyassoc.com/1949_1954_unive...
Note the cork seal pictured. It is tapered on the inside, or should be to match the radius of the ball on the slip yoke.
Age: 67 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
MotorCity57
MotorCity57
Loc: Troy, Michigan
Reg: 06-08-05
10-14-21 06:37 PM - Post#2829183
    In response to eplantage
Thank you all. I'll relay that info to my mechanic.
chevyivar
Loc: Norway
Reg: 08-30-12
10-14-21 10:51 PM - Post#2829192
Seems to me that you allready have the cork installed.
Was the same on my 54conv.
The torque tube will slide backwards rubb/seal against the cork when you tighten the round nut.
Off topic, but what is the prices in the US overhauling a 54 powerglide?
1939 Chevrolet Master Deluxe 85
1954 Chevrolet Bel Air Sport Coupe
1954 Chevrolet Bel Air Convertible
Edited by chevyivar on 10-14-21 10:53 PM. Reason for edit: No reason given.
MADMIKE66
MADMIKE66
Loc: ENGLAND
Reg: 06-18-14
10-15-21 12:08 AM - Post#2829194
    In response to chevyivar
I would say chevyivar is correct, tighten the round Sleeve nut but make sure the small cork seal and washers are inserted in the sleeve nut. but then again you might need less shims.
Edited by MADMIKE66 on 10-15-21 12:54 AM. Reason for edit: No reason given.
MADMIKE66
MADMIKE66
Loc: ENGLAND
Reg: 06-18-14
10-15-21 02:35 AM - Post#2829196
    In response to MADMIKE66
I'v been looking over your photos and think you are missing the ball joint seat and "O" ring seal. sorry i can t find a photo of it. It is fitted before the shims.
it looks like a dish with no bottom and bolt holes on the rim.
Edited by MADMIKE66 on 10-15-21 03:00 AM. Reason for edit: No reason given.
MotorCity57
MotorCity57
Loc: Troy, Michigan
Reg: 06-08-05
10-15-21 04:58 AM - Post#2829199
Are you referring to the black ring in the attached kit?
Link
Attachment: 3723490p.jpeg (67.05 KB) 1 View(s)
Edited by MotorCity57 on 10-15-21 05:05 AM. Reason for edit: No reason given.
MotorCity57
MotorCity57
Loc: Troy, Michigan
Reg: 06-08-05
10-15-21 05:02 AM - Post#2829200
chevyivar: we had trouble finding a shop to rebuild the powerglide. We ended up using the services of an 80-year old mechanic who was about to retire. I think my tranny was his last rebuild. My cost was around $800.
MADMIKE66
MADMIKE66
Loc: ENGLAND
Reg: 06-18-14
10-15-21 05:29 AM - Post#2829202
yes thats the "O" ring that goes on u jount ball seat. it talks about this seal and seat that im 100% sure you are missing in the work shop manual. have a look that the link.
http://chevy.oldcarmanualproject.com/shop/1949_53/...
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
10-15-21 09:45 AM - Post#2829211
This is a photo of a 1951 PowerGlide and I'm not sure how that might differ from a 1954, but my guess is you are missing the ball joint front seat [36]. You can see the small screw driver prying it away from the transmission case in the photo below. I believe MADMIKE66 made reference to it in an earlier post along with the "O" ring [37]. Some folks get a better idea when a visual is provided.
Attachment: 1951_PowerGlide_Ball_Joint_Front_Seat.jpeg (2.61 MB) 2 View(s)
Attachment: Close-Up_1950-54_PowerGlide_Torque_Tube_Ball.jpg (943.05 KB) 1 View(s)
1951 Fleetline Preservation
MotorCity57
MotorCity57
Loc: Troy, Michigan
Reg: 06-08-05
10-15-21 06:04 PM - Post#2829232
    In response to RAM_51
Excellent help - thank you all. We (mechanic and I) have ordered parts and will hopefully complete the project next week. I will report back then.
John W.
Execution time: 0.153 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:25 PM
