Username Post: Factory fuel injected 58 Impala        (Topic#366675)
Member #51
10-11-21 04:10 PM - Post#2828991
Some of you may (or may not) remember I posted that I was getting what was supposed a FACTORY built 58 FI Impala.
The FI unit was removed and replaced with a 4bl carb setup (first thing that makes it suspect).
A few months ago I got the FI unit, air cleaner assembly and multiple misc parts. The FI unit is now rebuilt and sitting on the fixture ready to be installed.
The gentleman who owned the car passed away 2-3mo ago, and his widow called to see if I would still install the FI unit and related parts on the car.
Well, this morning a friend of the family delivered the Impala on a trailer---------------12, 000mi on the odometer. It is an ULTRA nice Impala, has clear plastic covers on what APPEARS to be original, virgin seat covers.
So far, I have removed the dist, 4bl carb and intake manifold. Next step is to thoroughly clean the top of the engine to assure good gasket sealing and then start installing the FI unit, air cleaner and misc parts that SEEM to be unique pass car ONLY FI related parts.
I have NEVER in my life seen a GENUINE factory FI 58 Impala, SOOOOOOOOOOOOOOOO, I can only guess how one should look. As I said, there are various parts that appear to be pass car ONLY FI parts. A few weeks ago, I was running thoughts through my head about what to look for when I got the car. One of those things is the connector on the firewall wire harness that would connect to the elec wires on the FI unit. THAT CONNECTOR IS ON THE CAR AND APPEARS TO BE PART OF A FACTORY CORRECT WIRE HARNESS!
So, the more I examine this 58 Impala, it seems to be the real deal.
I'll update as time goes by.
Attachment: DSCN2611.JPG (4.33 MB) 5 View(s)
Attachment: DSCN2613.JPG (4.28 MB) 1 View(s)
Attachment: DSCN2614.JPG (4.33 MB) 2 View(s)
Attachment: DSCN2612.JPG (4.23 MB) 3 View(s)
Attachment: DSCN2615.JPG (4.39 MB) 4 View(s)
Member #51
10-11-21 04:11 PM - Post#2828992
Oh ya, and 3 more things it has:
It is a Flint block (FI engines ONLY came from Flint, no FI engines were built at Tonawanda).
EC on the engine stamp pad, correct code for FI and Turboglide, and it has the exhaust crossover pipe under the oil pan. The car has a Turboglide ------------------ NOT a PG!
The more I look at it and the more FI related parts I run across, make it appear as the real deal!!!
Attachment: DSCN2616.JPG (4.47 MB) 2 View(s)
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
10-11-21 08:19 PM - Post#2829005
Looks great! A rare find
Late yr model (Dec. 51 Bel Air/ 52 trim), with a basically stock 68 Camaro SS350/300hp Turbo Fire Edelbrock 1405,Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st places, and 1 top five award trophies so far
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
10-12-21 02:06 AM - Post#2829006
    In response to Lead sled
Wow Tom, this is a special car and you are the fellow who should have his hands on it.
Member #2194
corvesy
corvesy
Reg: 08-07-08
10-12-21 05:58 AM - Post#2829011
    In response to DonSSDD
Looking good keep us posted.
LtFrankDrebin
LtFrankDrebin
Loc: Coopersburg, PA
Reg: 01-25-01
10-12-21 08:16 PM - Post#2829061
Very nice! And one of my favorite color combos.
'56 210 Townsman wagon 6cyl/3spd OD | '58 Impala Sierra Gold 348
Member #51
10-13-21 06:40 AM - Post#2829074
    In response to LtFrankDrebin
So far, so good.
And as can be seen, it has PS and PB.
Attachment: DSCN2618.JPG (4.4 MB) 2 View(s)
DonSSDD
DonSSDD
Reg: 08-21-01
10-13-21 08:12 AM - Post#2829078
Temperature sensor on passenger side, never saw that before. Or that style of master cylinder.
Member #2194
Member #51
10-13-21 12:13 PM - Post#2829092
Don,
ALLLLLL Fuel injection adapter plates ONLY have the temp sender on the right side----------------AND THE TEMP WIRE IS THE PERFECT LENGTH TO REACH! Just one more indicator that it is the real deal.
SSuper Dave
Loc: Pearland TX
Reg: 10-02-05
10-13-21 04:36 PM - Post#2829109
Tom, what is that round hole in front of the block that looks like a distributor hole?
1968 Caprice coupe, 327/275, TH400, Ash Gold/Ivy Gold, Tach Dash, Tilt, Buckets, Console, AM/FM, Rear Defog, Disc and Rallys.
1970 El Camino, 350, TH400, 12 bolt posi, a blank slate!
8683jb
Reg: 09-06-13
10-13-21 04:48 PM - Post#2829111
What a time capsule! How cool! Regarding the picture with the carburetor - how'd they put oil in it? There doesn't appear to be an oil fill tube and the valve covers are closed.
Member #51
10-13-21 05:33 PM - Post#2829115
    In response to SSuper Dave
EARLY blocks had that hole. It was directly under the hole in the intake for the oil fill tube. It was simply eliminated on later block castings
Attachment: 100_1882.JPG (1.09 MB) 2 View(s)
Attachment: 100_3513.JPG (1.03 MB) 1 View(s)
Attachment: DSCN1448_zpssdm8jhgd.jpg (145.05 KB) 1 View(s)
Member #51
10-13-21 05:36 PM - Post#2829116
    In response to 8683jb
  • 8683jb Said:
------------------------- ---------------------- - how'd they put oil in it? There doesn't appear to be an oil fill tube and the valve covers are closed.
THAT HAS EXACTLY BEEN MY QUESTION!!!!!!!!!!!!!!!!! !!!!
Maybe put a tiny funnel in the dipstick tube and pour it in there????????????????
64ss409
Reg: 12-04-02
10-14-21 07:38 AM - Post#2829140
If I am seeing this right it looks like the oil fill tube would go in the front of the intake and angle to the passenger side. In the newer blocks the oil would go in the valley. There are drain holes.
Ron
1962 SS convertible, 327/250 4 spd
1956 IH pickup, 327
DonSSDD
DonSSDD
Reg: 08-21-01
10-14-21 08:02 AM - Post#2829142
    In response to 64ss409
Ron
Ron, not sure if your oil fill comment related to the earlier post asking where did they put oil in? In the picture above with the carburetor that was on this car, there is no oil fill tube and that is what the oil fill comments referred to.
Did you see Tom’s earlier separate post about this car?
Member #2194
64ss409
Reg: 12-04-02
10-14-21 08:20 AM - Post#2829144
My mistake. I see the problem now.
Ron
1956 IH pickup, 327
Member #51
10-14-21 12:18 PM - Post#2829159
The adapter plate for ALLLLLLLLLLL Rochester FI units has the oil till tube facing the right (pass) side.
The 2x4 manifolds also has the oil tube facing the right side.
Most all other manifolds (iron and alum) have the oil fill tube facing the left side.
Attachment: DSCN1609.JPG (2.13 MB) 1 View(s)
Attachment: 100_2746.JPG (1.16 MB) 1 View(s)
Attachment: Baseplate_for_7320.JPG (1.07 MB) 1 View(s)
Attachment: DSCN0878.JPG (854.92 KB) 1 View(s)
Attachment: sucp_0701w_10_z_57_chevrolet_dual_quad_283.jpg (74.1 KB) 1 View(s)
Member #51
10-14-21 12:24 PM - Post#2829160
Here is an iron and an alum Chevrolet single 4bl manifold with the oil fill pointing to the left.
The alum intake manifold is an early Z28 intake which I had on the 389 in the 51 before I put the 2x4 setup back on.
Attachment: 0730814-R1-024-10A.jpg (1.54 MB) 2 View(s)
Attachment: 100_3640.jpg (1.01 MB) 2 View(s)
VIN 58
Loc: ct
Reg: 03-23-10
10-15-21 02:07 PM - Post#2829222
Tom I noticed the one piece bumpers and that makes it a California car. That is one awesome survivor. Vin
grechevy
grechevy
Loc: delaware
Reg: 01-25-09
10-15-21 03:39 PM - Post#2829223
dz i was under impression all 58 smallblocks were staggered valve cover heads?thanks for any enlightment
Member #51
10-15-21 05:38 PM - Post#2829229
    In response to grechevy
ALLLLLLLLLLLL, repeat, ALLLLLLLLLLLLL 55-59 SB heads had the staggered bolt pattern for the valve covers--------------UNTIL , PAY ATTENTION, UNTIL late 59. In late 59, the heads were changed to the straight across bolt pattern.
Now, with that said, the 400 in my 56 Corvette has 1966 2.02 heads with a bolt pattern for staggered bolt pattern valve covers. How did that happen?
SSuper Dave
Loc: Pearland TX
Reg: 10-02-05
10-15-21 07:04 PM - Post#2829234
Same way it has the older markings on the ends of the heads?
Member #51
10-16-21 04:56 PM - Post#2829300
A little more progress and a question about a vacuum fitting.
Attachment: DSCN2624.JPG (4.27 MB) 1 View(s)
Attachment: DSCN2623.JPG (4.47 MB) 0 View(s)
Attachment: DSCN2622.JPG (4.34 MB) 1 View(s)
This is a vacuum fitting which was on the AFB carb. I can only guess it was on the FI unit previously. There has to be THREE vacuum sources for this car: one for the pwr brk, another for the transmission and a 3rd for the distributor vacuum advance. Right? SOOOOOOOOOOO, has anyone seen this kind of vacuum fitting? It obviously has a one way diaphragm or check valve for the pwr brk. I can blow on one end and air flows. I can blow on the other end and no air flow.
Jalapeno
Member #252
Loc: The Republic of Texas
Reg: 04-30-00
10-20-21 05:38 AM - Post#2829520
Tom, that vacuum check valve is correct for 1958 power brake. As for the TG vac source, I need to unbox my books (I just moved to the Hill Country near Austin) and take a look at the TG specs. I'll try to do that soon.
AWESOME car! Such a rare one, and so original. You are a lucky man to get to have this one in your shop. I know you've been taking pictures!
Jalapeno
Execution time: 0.101 seconds.   Total Queries: 24   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:01 AM
