Username Post: 2005 Impala 3.8 water pump gasket        (Topic#366604)
tibbitts
Reg: 06-16-03
10-05-21 08:20 PM - Post#2828596
Fel-Pro has the blue 35351 and the metal 35804 water pump gaskets listed for the 3.8L (2005 Impala.) The documentation says some water pumps (not mine) are stamped that they require a metal gasket, so the choice for them is obvious. But is the metal better for (or does it even work on) all water pumps? Or do both work on all pumps/engines, but maybe one model or the other seals better on irregular surfaces vs. have better pressure resistance, or have some other pro/con tradeoffs (other than price?)
Execution time: 0.087 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:03 AM
