Username Post: Front caster adjustment problem        (Topic#366534)
Vivian53
Vivian53
Loc: Florida
Reg: 09-10-21
09-27-21 07:50 AM - Post#2828098
Hello,
Thanks for letting me join. I have a 53 Bel Air that the pass side wheel leans to far inward. I can move the front control arm eccentric bolt but it doesn't move the wheel far enough to straighten it out. I don't see any other adjustments or places for shims. Help!
Joseph Dull
Site Ambassador
09-27-21 09:14 AM - Post#2828110
    In response to Vivian53
I’m not familiar with the setup on these cars. But what you are describing is a camber problem, not caster. Caster is the angle of the steering knuckle front to back. I know ‘55-‘57 Chevys sometimes suffer from crossmember sag. That is when the crossmember between the front suspension bends down in the middle and let’s the frame rails get closer to one another, which pulls the upper control arm mounts inward and tips the tires in at the top.
1957 Cameo Carrier
alltak
alltak
Loc: dallas texas
Reg: 10-04-04
09-27-21 02:26 PM - Post#2828132
    In response to wagonman100
Here is the link to the shop manual that describes the front suspension and how to align it.
http://chevy.oldcarmanualproject.com/shop/1949_53/...
I had a shim under the lower control arm, when i dis-assembled mine. I probably need to put it back in...
Attachment: IMG_0478.JPG (1.45 MB) 4 View(s)
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
09-27-21 04:28 PM - Post#2828141
    In response to alltak
https://youtu.be/ox1TOwI2tD8
a video i made when dealing with this. doesnt answer your exact question, but may help as you work through
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
09-28-21 05:28 PM - Post#2828218
    In response to drew1987
Gave you a thumbs up good video.
drew1987
drew1987
Reg: 02-23-14
09-30-21 04:24 PM - Post#2828312
    In response to Mike JW
I appreciate you!!!!
Member:
Vivian53
Vivian53
Loc: Florida
Reg: 09-10-21
10-05-21 06:59 AM - Post#2828542
Thanx, got my words wrong. I'm new to this site so I'm still trying to send a pic for reference. Anyhow, I don't think this beefy axle/cross member is gonna sag!
Joseph Dull
Vivian53
Vivian53
Loc: Florida
Reg: 09-10-21
10-05-21 07:13 AM - Post#2828543
Thanx, I tried moving the pivot pin but it doesn't move far enough to fix my problem. Soooo...a shim(s) installed under the bottom of the control arm will bring the top of the tire out? Makes sense.
Joseph Dull
stylelineone
stylelineone
Loc: Canada Vanisle
Reg: 03-21-18
10-05-21 07:49 AM - Post#2828551
The shim under the lower control arm is for caster adjustment.When there isn't enough adjustment in the upper shaft.Wont move the top of your wheel out as that is a camber adjustment. You must have worn out upper bushings or a damaged upper control arm, It could also be that the crossmember has been bent.
Vivian53
Vivian53
Loc: Florida
Reg: 09-10-21
10-05-21 08:10 AM - Post#2828552
    In response to stylelineone
I'll have to check again. All bushings are new and I checked the control arm and cross member.
Joseph Dull
Vivian53
Vivian53
Loc: Florida
Reg: 09-10-21
10-05-21 08:18 AM - Post#2828553
Thanx for the video!
stylelineone
stylelineone
Loc: Canada Vanisle
Reg: 03-21-18
10-05-21 12:11 PM - Post#2828558
On my car the most I can get is 1°negitive camber.I have tryed to get ° but not enough adjustment. Mustang II upgrade/downgrade??
drew1987
drew1987
Reg: 02-23-14
10-05-21 06:21 PM - Post#2828587
I have consisted slitting my front arms and moving the ends of them forward 3/32 or so. That would add caster. Likely after adding power steering
Member:
stylelineone
stylelineone
Loc: Canada Vanisle
Reg: 03-21-18
10-06-21 03:19 PM - Post#2828648
You can add castor by shimming the lower control arm.
stylelineone
stylelineone
Loc: Canada Vanisle
Reg: 03-21-18
10-06-21 03:30 PM - Post#2828650
I am installing a Calivier rack this winter. I have all the brackets made just waiting for some other parts. I am also installing left side Corvette adjustable tie rod sleeve. Hopefully this will tighten up the steering as a 1954 steering box helped but it still has some play it the steering.
drew1987
drew1987
Reg: 02-23-14
10-06-21 05:04 PM - Post#2828666
Isn’t that kind of “the wrong direction“ like an up and down instead of for and aft? Must take a lot of shims?
Member:
stylelineone
stylelineone
Loc: Canada Vanisle
Reg: 03-21-18
10-06-21 08:14 PM - Post#2828680
Caster is adjusting the tilt front and back from vertical. If more caster is required that the adjustment will allow, one side of the lower control arm can be shimmed.
drew1987
drew1987
Reg: 02-23-14
10-07-21 05:06 AM - Post#2828699
Yes, but I am just wondering how that all plays out. Sliding the control arm mounting points forward with dramatically increase adjustability with only a small amount of sliding. Shimming would require quite a bit to amount To the same degree of adjustability, right?
Member:
Vivian53
Vivian53
Loc: Florida
Reg: 09-10-21
10-12-21 03:33 PM - Post#2829036
Thank you all so much. I'm sorry I mis-wrote and waisted your time. Sooooooo...the problem I have is negative camber. Anyone wanna help me again?? haha
10-12-21 03:56 PM - Post#2829039
What are you using to check camber. What does the other side read?
Car sits level left to right? Not too low in the front?
Vivian53
Vivian53
Loc: Florida
Reg: 09-10-21
10-13-21 07:47 AM - Post#2829077
Shepherd,
I'm just using a bubble level for now. I have the fenders and hood off and pretty sure the alignment will change after the weight of the parts are back on. The driver side is straight up and down. The pass side leans in at the top. The camber adjusting bolt won't move the top of the wheel out far enough. The ride height isn't too low and she sits pretty level (barely off a little)
10-13-21 09:08 AM - Post#2829081
Ok, look for looseness in the kingpins, wheelbearings, any thing worn in the control arm bushings.
Vivian53
Vivian53
Loc: Florida
Reg: 09-10-21
10-16-21 12:12 PM - Post#2829268
Make sure king pins are tight.....check
Make sure new bearings are tight...check
Make sure new control arm bushings are tight...check
Look for bent or damaged parts....check
Make sure spring is in the right position...check
Make sure new shock is installed correctly...check
Make sure new sway arm bushings are tight...check
What did I miss?? haha
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
10-19-21 03:49 PM - Post#2829499
My '54 has about 1/4" of shims on the passenger side lower control arm, and it just barely has enough range to meet specs. I did't add these; possible may be part of the original assembly process.
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
Vivian53
Vivian53
Loc: Florida
Reg: 09-10-21
10-20-21 06:59 AM - Post#2829527
    In response to dsacton
I can assume you are referring to shimming the control arm shaft?
Execution time: 0.123 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:40 AM
