Username Post: 1959 impala LS swap        (Topic#366531)
The Flash
Reg: 09-25-19
09-27-21 04:54 AM - Post#2828087
Hi
I'm installing a 5.3 with an F-Body Pan in the impala with a 4L60E.
I have it in but it's rigged.
I have a ICT swap plate on the engine 2 washers (because the mount has a hump in it) then a chevy mount bolted to the original frame mounts.
I have the clearance I need but I want a better cleaner setup for the engine.
what adapter plates is everyone using? so far I'm leaning to the brphotrods Kit but its $$$ and not adjustable
https://photos.app.goo.gl/9f8mrhgFXmPG6V8D6
thanks
1947 Chevy Stylemaster Coupe
1959 Chevy Impala Coupe
1966 Olds 98 Convertible
1993.5 Toyota Supra Turbo
Edited by The Flash on 09-27-21 05:06 AM. Reason for edit: No reason given.
MikeUSNRet
MikeUSNRet
Loc: Northwest Arkansas
Reg: 07-14-11
09-28-21 08:06 AM - Post#2828167
    In response to The Flash
I'm using Street & Performance plates with Energy Suspension red mounts. I don't know if the S&P plates are still available.
You can also grind the bumps off of your mounts to eliminate the spacing issue.
Curious, what are you using for a transmission crossmember and mount?
MikeUSNRetired
1959 El Camino 5.3, 4L60E, 9" 3.70 Tru Trac
Execution time: 0.18 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:58 PM
