Username Post: ...this sucks...        (Topic#366523)
tsegnit
Loc: NY
Reg: 02-04-07
09-26-21 11:48 AM - Post#2828003
Everything working A-OK... upon arriving home, could not turn off headlights, had to disconnect battery. Discovered that headlight switch was very loose and upon removal, the ceramic was broken as well. Picked up new ("Standard" brand) switch. Can turn off headlights now, BUT when high beams are on, they start to flicker rapidly and bulkhead wire gets toasty (the entire front clip was treated to new wiring harnesses about a year ago).
Switched out the dimmer switch also; still NG.
Disconnected the high beams; low beams and turn signals not a prob.
So, we are stumped. Any suggestions appreciated.
Thanks................................
Life's Journey is not to Arrive at the Grave Safely in a Well preserved Body, rather to skid in Sideways, totally worn out, shouting "Thank you God, What a Ride!"'
Mercedes
Reg: 07-09-18
09-26-21 12:24 PM - Post#2828010
    In response to tsegnit
I would first check that master connection on the firewall under the hood. It is a known source for the wires to get loose in the plastic jacket.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
09-26-21 01:27 PM - Post#2828023
    In response to Mercedes
The new reproduction headlight switch strikes again I’d bet, they have a circuit breaker inside them, a filament strip. I soldered an external circuit breaker to replace the strip or find an NOS one.
Send that new one back.
Member #2194
Edited by DonSSDD on 09-26-21 01:29 PM. Reason for edit: No reason given.
tsegnit
Loc: NY
Reg: 02-04-07
09-26-21 04:53 PM - Post#2828049
    In response to DonSSDD
not sure if it's a repop... came from O'REilly's Auto Parts and is a "STANDARD" electrical item. Have to dig a bit more... thanks...
tsegnit
Loc: NY
Reg: 02-04-07
09-26-21 04:54 PM - Post#2828050
...been there, done that. All seems kosher. Thanks for the reply...
09-26-21 05:14 PM - Post#2828053
I've run relays for the headlights on my restorations for many years. The headlight switch controls the relay, which uses a small amount of current, while the relay handles the load of the headlights, which is a larger amount of current.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
09-26-21 07:27 PM - Post#2828064
Here's what rrausch is talking about.
http://madelectrical.com/electricaltech/bright er-h...
Brian
tsegnit
Loc: NY
Reg: 02-04-07
09-27-21 08:31 AM - Post#2828104
Def going to follow your recommendation, but only when I can isolate and fix the "flickering" high beam issue.... many thanks!
tsegnit
Loc: NY
Reg: 02-04-07
09-27-21 08:32 AM - Post#2828105
    In response to 55 Shaker
thanks for the link! I never realized the voltage drop....................
55 Shaker
Reg: 03-13-06
09-27-21 09:42 AM - Post#2828112
This how you would fix the light problem. My 55.2 3100 Chevy truck lights would go out when I put the brights on. Wired in the relays, and no more problems.
09-28-21 04:30 AM - Post#2828151
Thanks for posting the link to MadElectrical Brian. That's exactly where I got my supplies.
Execution time: 0.09 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:31 AM
