Username Post: How can I test power door lock relay        (Topic#366509)
chevrolation
Reg: 07-09-16
09-25-21 07:45 AM - Post#2827930
I'm in the middle of a very frustrating electrical issue with my 99 Tahoe 4 door I can lock and unlock all the doors with the remote but I cannot lock and unlock the doors with door switches I have unraveled all the wires in the doors and checked them all for continuity, fixed wires that have been cracked or frayed by door opening and closing so I'm at the point that I think I need to check the door lock relay but I don't know how to test that to make sure it is working any help would be greatly appreciated
2016 express 3500
1999 tahoe 4dr
Site Ambassador
09-26-21 07:39 PM - Post#2828066
    In response to chevrolation
If the locks work from the remote but not the door switch, it is not a relay. You can switch it with another known good relay, but I think you will find you will have the same problem. You can put your hand on the relay as you use the remote and you will fell a vibration and hear a click as the relay activates. I think you probably have a bad lock switch(es). On some vehicles, if the master switch on the drivers door goes bad, the other switches won’t work.
1957 Cameo Carrier
chevrolation
Reg: 07-09-16
09-27-21 03:10 AM - Post#2828080
    In response to wagonman100
Sorry, I should have mentioned that I put a new switch in drivers door when wires seemed to be in good condition
2016 express 3500
1999 tahoe 4dr
Execution time: 0.091 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:44 AM
