Username Post: afr gauge        (Topic#366504)
blusv1
Reg: 07-30-19
09-24-21 03:28 PM - Post#2827891
i have a autometer digital afr guage i my 66 impala the sensor worked when i had the small block in it
now that i put my big block in it, it does its count down it goes to 14.9 and stays there. so i bought a new gauge and it does the same but stays at 15.1 . any thoughts on this...autometer never answered my question to them
thanks
TIM
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
09-24-21 03:35 PM - Post#2827892
    In response to blusv1
your autometer digital afr gauge may be ok, the oxygen sensor(s) battery voltage ,or the electrical connections or electrical grounds may be defective
Edited by grumpyvette on 09-24-21 03:37 PM. Reason for edit: No reason given.
blusv1
Reg: 07-30-19
09-25-21 08:45 AM - Post#2827933
    In response to grumpyvette
i replace the whole kit gauge sensor and wires and wired it to the battery...no change.
TIM
IgnitionMan
Reg: 04-15-05
09-25-21 10:13 AM - Post#2827938
I have always used only two tuning parameters, "seat of the pants dyno", DRIVING the vehicle to tune it, and, "seat of the pants, and eyes A/F tuning" (drivng the vehicle, and pulling over and actually LOOKING at the plugs). This way, when I pass gas as I am driving, it doesn't throw my carb tuning off.
blusv1
Reg: 07-30-19
09-25-21 11:46 AM - Post#2827942
    In response to IgnitionMan
theres no issues in how it runs it runs great, plugs are spot on..i like having the info like the o pres and w temp,
TIM
65_Impala
Reg: 12-29-02
09-26-21 05:50 AM - Post#2827976
How many wires on the O2 sensor? If it has less than 4 then the sensor needs to be grounded.
Mercedes
Reg: 07-09-18
09-26-21 08:22 AM - Post#2827986
Welcome to 1974.
IgnitionMan
Reg: 04-15-05
09-26-21 10:33 AM - Post#2827993
    In response to Mercedes
Mercedes, why are you locked into 1974, the rest of us are up to date today, and we really don't need a gauge to tell us when the engine is running properly. We learned how to do it the right way, all by ourselves, without an AFR gauge.
I am going out on a very stable limb here, and ask you if you know why there are AFR gauges today? I doubt you really do know why.
9 letter word, back from the 1974 era, that stays with us today ....... E M I S S I O N S. Factory production and EPA EMISSIONS levels jetting.
NOT PERFORMANCE, not street runner, EMISSIONS. An AFR gauge is an easy tool to use to set things like idle mixture screws, check for other jetting, timing issues, NOT as a performance, or
pre-emissions engine tuning device.
All, enjoy your delusions and fallacies.
blusv1
Reg: 07-30-19
09-26-21 11:43 AM - Post#2828000
    In response to 65_Impala
5 wire...
TIM
65_Impala
Reg: 12-29-02
09-26-21 04:02 PM - Post#2828044
It's a wideband for sure then.
Did you check it with a propane torch?
Maybe check that there isn't a voltage difference between the exhaust and the battery?
If it won't work on the bench then I'd send it back and get a replacement.
I was recently helping my buddy tune his ~900hp turbo LS truck using a wideband. The computer would even adjust the tune itself once you setup the lambda ratio table. A wideband is a pretty nice tool to have with a performance engine. A narrowband O2 sensor isn't much good, they are mostly only to know you are running stoichiometric.
Execution time: 0.078 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:10 AM
