Username Post: What serial number is on early 50 car title        (Topic#366495)
cfc63
Loc: KY
Reg: 10-31-17
09-23-21 02:02 PM - Post#2827814
Is it the number on the plate that is on the door post or number on engine.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
09-23-21 02:19 PM - Post#2827816
    In response to cfc63
Most states, back in the day, used the engine block number as the VIN on the title. I wasn't until 1951 that the body serial number on the "A" pillar was riveted on. Prior to that they were simply screwed into place making them very easy to switch. Therefore, as stated, most states used something that was a little more difficult to switch out which turned out being the engine. If it is a 1950 title the VIN number would begin with a "HA" which is how the passenger car blocks were stamped and if the block number was used.
1951 Fleetline Preservation
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
09-26-21 07:06 AM - Post#2827980
On my Michigan registered '50 Deluxe the door tag number is used.
Dean50
cfc63
Loc: KY
Reg: 10-31-17
09-27-21 03:36 PM - Post#2828135
    In response to Dean50
Would you be leery in buying a 50 car that does not have a door post tag. The title is OK as it has the engine serial number on it. I've read a lot of early 50 chevys used the engine number on title.
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
09-27-21 03:46 PM - Post#2828137
I would not worry about it if the title is ok now. My 50 was registered with the engine #. I'm in CA. where they always get there panties in a wad when registering an old car.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
10-12-21 02:41 PM - Post#2829030
    In response to Mike JW
I got a nice letter from the MO DMV, saying the local tag office had put my VIN down as the tag number, and my tag number as the VIN number. Have not heard anything since.
1952 Styleline Fourdoor, 62 235 Cast Iron Power-glide.
Six in a Row, makes Her go
Mike JW
Mike JW
Reg: 01-19-06
10-12-21 03:04 PM - Post#2829033
    In response to gcrkfrd
Good sounds like (problem solved)
Loc: Willoughby Hills, Ohio
10-12-21 04:07 PM - Post#2829040
Now back in Ohio, but when living in NC and now Ohio, the body serial number was used on the title.
Never could imagine why the engine number would have been used on a title, but it was ……
1951 Styleline Deluxe 2 dr sedan. 1955 235” / 3 speed.
Old Heap
Old Heap
Loc: SE Virginia
Reg: 03-31-18
10-16-21 02:11 AM - Post#2829241
    In response to bobg1951chevy
Virginia here, pillar tag was used as "Vin". My title was from Nevada when I transferred it. The Nevada title also used the pillar tag number.
1950 2-door Hard Top 350/350 EFI Speedway MII Front End
F**D Model A pickup Hot Rod (SBC for reliability)
1999 Silverado 4.3 5-speed daily driver
2017 Equinox LT Wife's car
Davesblue50
Loc: South Texas
Reg: 08-25-21
10-16-21 07:50 PM - Post#2829316
My NC title for the 50 coupe is for the door pillar tag number. It was just issued 2 months ago. Struck me as being strange using the engine number (I know some states did) as the engines were changed over time but the body IDs should stay the same.
Execution time: 0.089 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:14 AM
