Username Post: Converting manual steering        (Topic#366492)
65cayne
Reg: 08-21-07
09-23-21 07:13 AM - Post#2827772
I have a power steering car with a rebuilt power Saginaw 800 steering box that is having some issues. Since I currently do not have a power steering pump, I would like to convert to a manual and shelf that pump for a later project.
When converting to manual steering, it seems I will need a new pitman arm with a smaller (?) diameter hole on the big end.
Assuming this is true, does anyone know where I can source one?
1965 Chevy Biscayne
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
09-23-21 11:40 AM - Post#2827803
    In response to 65cayne
Where are you located? I know of three wrecking yards in the Northwest that still have '66 Impalas around. Also, if it happens to be the same PN as a '65 Chevy C10, I have a manual box from that truck when I converted to power steering. It still has the pitman arm on it.
65cayne
Reg: 08-21-07
09-23-21 12:05 PM - Post#2827806
    In response to jktucker92
I am in the midwest. I am not sure the C10 uses the same box or pitman arm. Thanks though.
1965 Chevy Biscayne
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
09-23-21 03:19 PM - Post#2827824
you can google search o.e. P# 3864703, '65-66 full size (Impala/Belair/Biscayne) non p/s, forged # 3855955.
I have my O.E. manual box with arm still attached. I'd rather not split them if all you need is the arm but if you need both we can talk!
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
Edited by docjns1 on 09-23-21 03:20 PM. Reason for edit: No reason given.
65cayne
Reg: 08-21-07
09-23-21 04:00 PM - Post#2827828
    In response to docjns1
I was planning to buy a new box but wouldn't be opposed to a good working used one
1965 Chevy Biscayne
Execution time: 0.218 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:46 PM
