Username Post: upgraded to LED headlights        (Topic#366490)
r6vr6
Reg: 09-11-21
09-22-21 05:07 PM - Post#2827724
With it getting darker earlier our nightly Cruises were ending with it being dark. The old sealed beams just were not enough with the more modern lighting we have come accustomed too. Got a LED 5.75 H4 kit. Easy install and everything works as it should. I went with the crystal lens but they do make ones that look like the old sealed beams if that is your thing. the low beams are nice and white. The highs are awesome. very happy so far.
low beam
high beam
this is the kit
Link
Edited by r6vr6 on 10-06-21 02:42 PM. Reason for edit: No reason given.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
09-23-21 02:40 PM - Post#2827821
    In response to r6vr6
Looks nice! Did you have to modify the buckets to accomodate the beams and was there anything special to do with wiring?
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
r6vr6
Reg: 09-11-21
09-23-21 05:39 PM - Post#2827842
    In response to docjns1
No modifications needed. you could probably piece a set together cheaper but everything fitting was a concern for me. they seem to be burning in a little as they seem a little brighter the last couple of nights. really happy with the change. the brights are just ridiculous, in a good way.
Mel Foye
Mel Foye
Reg: 09-29-00
09-23-21 08:14 PM - Post#2827845
Really a plus when you are hoping something will be an improvement and it is.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
09-25-21 08:31 AM - Post#2827931
Sounds great, think I'll give them a try. Don't drive it much this time of year after dark but will be a big improvement.
Steve
327 / 300 L74
M11 3 on the tree
r6vr6
Reg: 09-11-21
09-25-21 10:58 AM - Post#2827939
it's night and day difference from the old sealed beam. significantly better vision. not too bright for on coming traffic either as I have not had anyone flash me...even the couple times I forgot about my brights.
Olsonpopper
Loc: Cape Canaveral, FL
Reg: 09-05-21
10-15-21 07:28 AM - Post#2829209
I tried looking online for these headlights. It got a little confusing. Would you mind letting me know what you actually ordered?
Thanks.
r6vr6
Reg: 09-11-21
10-15-21 11:57 AM - Post#2829217
    In response to Olsonpopper
this is exactly what I got
https://www.ebay.com/itm/5-3-4-Crystal-Cle ar-Metal...
Texasray
Texasray
Reg: 11-01-16
10-16-21 03:36 PM - Post#2829281
I have that same kit ordered from Octane back in 2018. The only difference is I ordered the halo lights in blue. About 6 months later I reordered the same with orange halo, I have them wired as daytime running on the low beam and blinker on the high beam. We also don't drive much at night but they come in handy when going to and returning from long distance car shows such as Cruisin' the Coast. If you get caught out at dusk or night you feel much better with these.
Sam
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
10-18-21 04:00 PM - Post#2829441
    In response to Texasray
Took r6vr6's advice and did same kit (mine were H4, tho...confused me a bit as they came w/H4 bulbs installed that you swap out with their LEDs and wiring)...as stated, no mods needed and everything included.
Octane Lighting's web site has them all, halos, non halos, all the colors etc. so be careful if you dont follow the above link.
Bottom line is i'm completely satisfied with the install, look* and most importantly performence!
* my car is yellow and the LED chips are yellow so the reflection thru the lens when off looks like they wre custom for my car!
Steve
327 / 300 L74
M11 3 on the tree
r6vr6
Reg: 09-11-21
10-18-21 05:28 PM - Post#2829450
great to hear you like them. I think they got brighter after the 1st couple nights. so they might get better if you haven't used them much. the brights are additive.
a couple more pics after some time on them:
OFF
LOW ( shows bluer than with the eye which looks white)
HIGH
Edited by r6vr6 on 10-19-21 04:23 PM. Reason for edit: No reason given.
Execution time: 0.09 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:44 AM
