Username Post: 65 Biscayne Moser rear end swap        (Topic#366481)
65cayne
Reg: 08-21-07
09-22-21 10:05 AM - Post#2827692
Hey guys,
Ordering a new 12-bolt rear end from Moser Engineering and they can ship it with control arm brackets installed for a '65 Impala (4-link). This means that there will be no provision for my Biscayne's existing panhard bar.
This also means that I would need to weld in an upper control arm bracket on my frame (driver side) since the Biscayne (mine anyway) only has the upper passenger side bracket.
Am I correct in assuming that, with the addition of an upper driver side control arm bracket, this rear end will bolt right in?
In other words, the impala rear suspension geometry (control arm bracket location, measurement, and layout) is identical to the Biscayne, except for the pan hard bracket and missing upper control arm bracket. Is this correct?
***UPDATE 10/15/2021***
Ordered my 12-bolt from Moser, set up with factory width and brackets "for a '65 Impala" (that's all they can tell you...it is up to the buyer to verify that it will work). It bolted right in without any problem whatsoever.
They install OEM type brackets, two uppers, and two lowers, and the passenger bracket does have the panhard bar hole if you choose to retain the three link setup. You would have to recover the stud from your old rear end.
More details down in the thread. Thank you everyone for helping with my questions.
-Kevin
1965 Chevy Biscayne
Edited by 65cayne on 10-15-21 09:33 AM. Reason for edit: No reason given.
ImpalaSam
Loc: Inman, SC
Reg: 07-02-09
09-22-21 11:53 AM - Post#2827698
    In response to 65cayne
I'm pretty sure the panhard mount is integral to the passenger side upper arm mount.
65cayne
Reg: 08-21-07
09-22-21 12:12 PM - Post#2827704
    In response to ImpalaSam
Correct. And on the impala, the bracket looks exactly the same sans the panhard bracket. At least I think it does. I do not own an Impala.
Maybe a better question for the group... Who here has swapped an impala 4-link rear end into a Biscayne?
1965 Chevy Biscayne
Edited by 65cayne on 09-22-21 12:34 PM. Reason for edit: No reason given.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
09-22-21 06:58 PM - Post#2827736
You will not have to weld a frame mount for the second upper control arm. The mounts are bolted on and are the same left and right. The upper control arms are the same also. When you install the additional arm/bracket be sure to add the shims between the mount and crossmember. You shim the new arm/bracket to match the other upper control arm. The panhard bar mounts are the same on the frame and rear housing be it 10 bolt or 12 bolt, 3 link or 4 link.
mjc1
mjc1
Loc: Burlington Ontario Canada
Reg: 09-15-04
09-22-21 07:12 PM - Post#2827737
    In response to aghaga
I'd assume the street Moser will use a GM 12 bolt core housing, so it should come with the hole in the upper passenger side mount for the Panhard bolt. All the frames in that 65-70 gen came drilled for the 4th upper arm regardless.
1965 Laurentian post, 1967 Grande Parisienne 4DR HT
My Flickr page
65cayne
Reg: 08-21-07
09-23-21 04:30 AM - Post#2827755
He said they will weld the brackets on the axle in the OEM location for a 65 Impala 4-link and there will be no provision for a panhard bar. Meaning I could not bolt it in and run it in my existing configuration with the panhard bar.
Any idea where I can get the upper driver side frame bracket?
My main concern is that for the three frame brackets I have now, they are in the correct location and will work with the Impala OEM 4-link axle. Then all I need to do is add that 4th bracket to the frame, get another upper control arm and delete my panhard bar.
It sounds like this is the case.
1965 Chevy Biscayne
65cayne
Reg: 08-21-07
09-23-21 04:45 AM - Post#2827756
    In response to mjc1
The housings are manufactured by Moser. They are not cores. However, you could be correct though. I know the bracket kit from Currie (for an Impala 4-link) indeed has that provision for the panhard bar that you are talking about. Maybe Moser's brackets will be the same. I intend to go to a 4-link set up but a panhard bar provision would get me on the road immediately.
Thanks guys for all your replies! It's been very helpful.
1965 Chevy Biscayne
ImpalaSam
Loc: Inman, SC
Reg: 07-02-09
09-23-21 08:40 AM - Post#2827779
My '65 Impala came with a 10 bolt and 3 link rear. I swapped in a 12 bolt with 4 link from a '69 Caprice. Everything fit without issue when I used the upper links from '65 because the upper links from the '69 were a different length, I think the upper crossmember is flipped and the upper links are shorter on the later cars.
Edited by ImpalaSam on 09-23-21 08:40 AM. Reason for edit: No reason given.
65cayne
Reg: 08-21-07
09-23-21 10:53 AM - Post#2827799
Thanks Sam
1965 Chevy Biscayne
65cayne
Reg: 08-21-07
10-15-21 10:32 AM - Post#2829212
Well I pulled the trigger on the Moser rear end. I installed it in place of the old GM 8.2 rear end along with two new upper adjustable control arms and two new mounting brackets.
The assembly can be fairly inexpensive however when you add some powder coat, a few upgrades, sales tax, and shipping, it gets quite expensive. With age, I find myself saving the extra $$ for the "once and done" solutions rather than trying to go the cheapest route. I came close to doing that (just repairing the stock rear) however after disassembling it, that would have been a terrible decision. It was on borrowed time long before the axle seal blew out.
I ended up getting a custom built rear with bolt in axles and GM "big" housing ends (Impala and truck only) to accept my factory backing plates. Other than adding the second upper control arm and having to order a new driveshaft (converted to 1350 U-joints), it is a straight bolt-in solution.
The complete assembly is as follows:
Moser 12-bolt housing with factory style brackets
3.73 gear set with 1350 yoke
Wavetrac helical limited slip (they were out of my other two choices...this was much more expensive but had a lifetime transferrable warranty)
35 spline axles with 3" x 1/2"-20 screw in studs (upgrade from planned 33-spline due to Wavetrac only accepting 35 spline axles... 10yr warranty on the axles)
Moser aluminum girdle (diff cover)
Powdercoat (semi-gloss black)
Plus two Globalwest TBC-51 upper control arms, and two VTC-50 brackets. Both brackets bolt right in as mentioned by another Poster.
The rear was delivered 13 days after I ordered it. Got here fast and undamaged but the crating/packing job was the pits.
If anyone has any questions, please ask. Thanks for everyone's help.
Time to heal the wallet now.
1965 Chevy Biscayne
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
10-16-21 07:22 AM - Post#2829249
nice upgrade, and a nice self given gift.
a $5000, well spend ...
"once and done" congrats !
My first car: 1970 Olds, 442,455 (1981-82)
My last car : 1966 Chev. Impala convertible,396 (1984-2020)
current car: Can't afford them anymore ...
mjc1
mjc1
Reg: 09-15-04
10-16-21 08:10 AM - Post#2829255
Could you post some images?
I'd love to see it.
My Flickr page
65_Impala
Reg: 12-29-02
10-17-21 07:21 AM - Post#2829339
You seem confused on the panhard bar. You always need it, even with a 4-link.
space66
space66
Loc: Montreal,Qc
Reg: 06-01-16
10-17-21 08:37 AM - Post#2829342
Is the Moser cover the same depth as original ? I've seen guys with after market aluminum case covers having clearance issues mounting the panhard bar ...
Execution time: 0.114 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:19 AM
