Username Post: air ride        (Topic#366471)
sanee64
Loc: atlanta ga
Reg: 04-05-18
09-21-21 11:39 AM - Post#2827609
Curious to those that have air bags in their ride and what you think about it. I still have a long way to restoring my 64 but this would give me lots of joy driving it around as the stance to it now kinda sucks. Ive no clue to how much these systems even cost but would come in a good time as i need my suspension updated. I appreciate any recommendation to what brands to use, where to get...etc
kingkreeton
kingkreeton
Loc: Nashville TN
Reg: 04-15-11
09-21-21 12:54 PM - Post#2827616
    In response to sanee64
My friend had bags on his 59, he constantly had issues with them.
You can always adjust your stance with different springs.
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
sanee64
Loc: atlanta ga
Reg: 04-05-18
09-21-21 04:55 PM - Post#2827645
    In response to kingkreeton
hey shane
was it a crap brand or are bags usually pesky?
ayelander
"3rd Year" Platinum Supporting Member
ayelander
Loc: Oak Island NC
Reg: 12-07-18
09-21-21 05:16 PM - Post#2827647
I have quality air bags on my 63 SS. Dont like them and will eventually change them out to an adjustable shock.
Ayelander - Oak Island NC
1951 Chevy 3100, 261 cu in, Dual Webers, Fenton Exh
1963 Impala SS, 500 HP, EFI 383 Stroker,Tremec 6 Speed
2013 Camaro 2SS, Convertible
2016 Chevy High Country, Diesel, Dually
sanee64
Loc: atlanta ga
Reg: 04-05-18
09-21-21 05:32 PM - Post#2827649
    In response to ayelander
Can you share your experience of why you dont like them?
ayelander
ayelander
Loc: Oak Island NC
Reg: 12-07-18
09-22-21 04:23 AM - Post#2827669
I guess I don't like being a "low rider". I
prefer a certain stance and leave it there. They can develop leaks over time (as mine has) so I have to constantly adjust
USCGMK1
Loc: Vicksburg, Mississippi
Reg: 07-24-15
09-22-21 08:34 AM - Post#2827685
Hopefully get my 64 bagged next spring. I’m parting my set up together and if I have enough money I plan on using hydraulic hose instead of the DOT airline. From what I’ve read and seen pictures of a lot of those expensive name brand company set-ups are junk. But nothing is 100% guaranteed.
sanee64
Loc: atlanta ga
Reg: 04-05-18
09-23-21 07:15 AM - Post#2827773
    In response to USCGMK1
thanks for all the replies. Just chatted with a buddy that rides on slam specialties bags, accuair on the controller and etc. No problems for him but it has a lengthy text on what to do and look for. Good to hear that part atleast. Its gonna have to be a well thought out process for me if i still want to go this route
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-23-21 07:38 AM - Post#2827775
If one's leg is broken, asking what crutch to use will allow mobility, but doesn't correct the problem.
If you car's 'leg is broken', air bags would be a 'crutch'; not a fix.
Springs, shocks, bushings, suspension parts on your car?
Just info.
Pete
61ragtop
Loc: Langley B.C. Canada
Reg: 07-30-03
09-24-21 02:03 PM - Post#2827881
    In response to japete92
I have had bags in my 61 since 2006 and love them. no issues or leaks, drives nice etc.....
I have accuair elevel no issues with it at all. take the time to research and install correctly with good parts... Make sure the bags have clearance in the coil pockets to avoid rubbing which will lead to leaks or a blowout.
I personally have 3/8 stainless lines and my car does not leak what so ever... Crappy push to connect will usually leak
56_Kruiser
56_Kruiser
Loc: St. Augustine, Fl
Reg: 09-23-05
09-26-21 06:24 PM - Post#2828057
    In response to 61ragtop
61 Ragtop is providing good advice.
I had airbags on my '56 convertible since '99. I did have to replace 1 air bag last year.
I haven't had any issues with leaks.
I put Ridetech's highest end bags on my '61. I like them. But, I have found the installation of the levelers problematic. You need to locate them for proper travel of the arms for determining the setting. I found that difficult.
Interestingly, while the car was at a shop they let the battery run down (another story). They put a high amp battery charger on it and blew out the computer for the Ridetechs.
The new system can set ride height by air pressure, and I find that quite adequate.
My attempt at building cars is for show qualitiy on body and interior...but plain Por-15 type of frame painting. No show underneath. The air bags makes it harder for the under side to be seen :laugh : Just joking...but I like a low stance at shows, and bring it up for driving.
1956 Chevy
Vid of 61
61 Chevy
mean60impalagene
Reg: 01-31-13
09-27-21 01:57 AM - Post#2828078
    In response to 56_Kruiser
Had my 60 bagged for a few years...great times. Ragtop 61 is on target. Research and then research.
Tex63
Reg: 05-09-17
09-27-21 07:58 AM - Post#2828099
My 63 wagon has ride tech without the level sensors. Chased small leaks until I hard plumbed between the pumps and air tank and no leaks since.
Only regret is the 1/4" lines and valve bodies. Had I known how slow the lift is would have gone bigger for sure.
BelAirBub
BelAirBub
Reg: 06-18-18
10-05-21 06:48 AM - Post#2828541
I have bags in my car. I used the least expensive design I could without getting too cheap on components. Manual valves, 3 gal tank, 1 small compressor, 1/4" lines, steel push to connect fittings. I got a bag and bracket kit off ebay and controls from Boris at Street Machinery. If I did it over again I'd just get everything from Boris. The ebay kit front bags wouldn't even lift the car with 100 psi in them so I had to get new bigger bags. I think 2600's. It sits for months and doesn't loose air. My only complaint might be I fiddle with the air pressure alot. I'm happy with the bags, pump, and tank. I'd like to add AccuAir e-level and height sensors.
1961 Bel Air Bubbletop
Execution time: 0.075 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:05 AM
