Username Post: Gas filter        (Topic#366469)
3964sp
Reg: 09-23-20
09-21-21 10:12 AM - Post#2827602
On my 396 Holley double Pumper. There is a gas filter on the line leading to carburetor. I've noticed this on several vehicles. Aren't the filters and the carburetor themselves adequate. Do I need this filter
Oshawa65SS
Loc: Grande Prairie AB & N...
Reg: 09-22-14
09-21-21 12:15 PM - Post#2827614
    In response to 3964sp
An inline filter upstream of the fuel pump is best, but the filter that screws into the float bowl on Holley's is ok, and much better than the Rochester system of a filter behind an inlet nut that the hard line threads into.
Fun and games holding the inlet nut still while tightening the hard line and not having a leak.
A fuel hose section between the filter and the hard line like with Holley carbs makes things so much easier, and isn't subject to the vibration a direct hard line connection is.
Ryan
Build date Dec. 21 '64 Oshawa
3964sp
Reg: 09-23-20
09-21-21 01:56 PM - Post#2827623
    In response to Oshawa65SS
Thank you very much that make sense
Execution time: 0.154 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:27 PM
