Username Post: 1970 GM "Hold Off Valve" for brakes        (Topic#366468)
1carguy
Reg: 11-30-08
09-21-21 10:06 AM - Post#2827600
My 1970 brake system has a "hold off valve" that is inline at the master cylinder that was apparently used on all 1970 GM vehicles with front disc brakes. I am replacing the stock master cylinder with an aftermarket aluminum master cylinder from Summit Racing. Question: should I reinstall the hold off valve or eliminate it? Since the lines are already plumbed for the valve it would be easier to just keep it in the system but I don't know if it's compatible with an aftermarket master cylinder. Any brake gurus out there?
09-21-21 03:25 PM - Post#2827632
    In response to 1carguy
Make sure the master you get is specifically designed for disc/drum applications, careful as Summit tends to tell you everything will work. Check the part number at other sites and check the application, if it is right hook it up as the oe was.
Mercedes
Reg: 07-09-18
09-26-21 12:54 PM - Post#2828017
I believe that valve is a pressure distribution valve that limits the pressure to the pressure to the rear wheels to prevent locking up the wheels.
09-26-21 02:08 PM - Post#2828034
make sure you get the bore size correct. seems that the only way to do that is to measure it.
Execution time: 0.137 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:05 PM
