Username Post: '63 Impala; removal of parking brake pedal assembly        (Topic#366448)
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-19-21 08:08 AM - Post#2827378
I'm trying to remove the 'alarm' light switch on my 63 Impala.
After groping around a bit under the dash, it seems that to get to the little screw that holds the switch to the pedal assembly, I'm going to have to detach the assembly from the firewall.
From the assembly manual, it looks rather simple. From under the hood; two nuts to remove. And a single screw up under the dash
I have never futzed with that pedal assembly. My questions are:
Disengage the parking brake first?
Disconnect the mechanical cable from the pedal assembly before removing the attachments? CAN one actually get sufficient access to disconnect the cable prior to unbolting the assembly?
Am I missing something (like more attachment points, or something else)?
In my view of a fair world, I simply disconnect the two bolts from inside the hood and the screw under the dash. Lower the pedal assembly to the floor, and remove the screw holding the switch body. To replace, simply reverse.
Although I am going to attempt to repair/restore the switch, I'm not confident I can do that. I will likely re-install the pedal assembly w/o the switch (temporarily so I can drive the car) until I get a replacement, or complete the repair.
Some helpful tips would be appreciated.
Oh, I have the electrical wires disconnected fro the switch.
Thanks.
Pete
58Yeoman
Loc: Burlington, Ontario
Reg: 12-22-15
09-19-21 09:02 AM - Post#2827383
    In response to japete92
Hi Pete. Your description of your plan "I simply disconnect the two bolts from inside the hood and the screw under the dash. Lower the pedal assembly to the floor, and remove the screw holding the switch body. To replace, simply reverse" should do the job. It took me just a few minutes to pull my '63 e-brake pedal doing it exactly as you described. It gave me full access to the switch. John
1958 Chevrolet wagon (Yeoman)
1961 Impala convertible
1964 Parisienne convertible (parts car)
1963 Impala 2dr (parts car)
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-19-21 09:28 AM - Post#2827387
    In response to 58Yeoman
Thanks.
It did not appear to be any more complicated than that, but I had never even looked at that part of the car before.
When I disconnected the wires to the switch, the spring, the wire connector, a little 'washer' and the 'bottom' of the switch can fell on the floor. When I get the remainder of the switch off, I'll renew my repair efforts.
Thanks again.
Pete
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
09-19-21 12:49 PM - Post#2827415
If you have enough cable length after removing the 2 firewall mounting nuts and the dash mount screw, just lay the assembly down to remove the switch.
If you want to remove the assembly from the car, you might have loosen cable under the car in front of the x-frame - by backing off the hex nuts on the assembly were the cable loops through the curved cable holder. You only have to do this if you can’t release the round ball on the end of the cable that is hooked through the parking brake assembly with the special bracket to hold the end of the cable.
..yes first you do completely release the parking brake even by pulling up on the pedal when pulling on the release handle on the assembly
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-19-21 02:05 PM - Post#2827420
    In response to pvs409
Thanks for the help.
I do not plan to remove the assembly from the car (unless I absolutely have to). But it is good to have some guidance on how to do it.
Thanks again.
Pete
Execution time: 0.105 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:08 AM
