Username Post: 59 El Camino headliner install tuck strip        (Topic#366447)
eclectic57
Loc: Idaho
Reg: 05-23-06
09-19-21 08:00 AM - Post#2827376
I'm replacing the headliner in my 59 El Camino and it has sheet metal strips above the doors with triangular "teeth" stamped out of them. When I stretch the headliner vinyl to the side, what holds it in place? I assumed the teeth but they will not penetrate the vinyl. I made a u shaped tool to pull the vinyl onto the teeth but it comes loose when I work on the next section. The videos I have seen show the vinyl being tucked with a putty knife type tool and magically staying in place. Is this glued on the smooth face of the strip and the extra material tucked when done just to hide it?
Execution time: 0.089 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:28 AM
