Danchuk
Username Post: LEAK DOWN VARIANCE IN SBC        (Topic#366437)
vabeach56wagon
Loc: Chesapeake,VA,
Reg: 04-22-02
09-17-21 05:41 PM - Post#2827287
A 302cu in SBC, fresh with Eagle crank, rods,JES forged 11-1 pistons, comp flat tappet cam, heads fresh, fel-pro 17030 composite head gaskets, square decked block....
Did a leakdown test out of curiosity after the right bank cylinder head had to be replaced because of a cracked seat. Newly-done head was installed but has developed slight head gasket leakage into #6.
Pulled the head, replaced the damaged gasket, retorqued head and got out the leakdown gauges. All four cylinders on that bank are at a 20psi difference. All four cylinders on the left hand bank are at 10-15 psi difference.
Should I be trembing in dismay or should I finish buttoning up the motor with the thought that the seal on the right bank will improve once the engine has fired again?
paul
Original builder of the Gobstomper - '56 210 9 passenger wagon now in other's hands. Current Ride is '69 X33D80 Z28 Camaro
09-18-21 04:12 AM - Post#2827298
    In response to vabeach56wagon
Where is the leak, you can hear it in the intake, exhaust or crankcase. 20% is high.
Execution time: 0.087 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:59 AM
