Username Post: Rubber Freeze Plugs        (Topic#366418)
Che94
Reg: 04-04-21
09-16-21 07:39 AM - Post#2827187
..the ones that expand when the nut is tightened. I can not find any spec or even a suggestion on how "tight" is tight enough. 1-5/8" plug in a near 1-5/8" hole, located behind the AC compressor mounting bracket. '94, 350 engine.
Anyone got a suggestion or torque spec?
Thanks in advance...
Senior Moderator
09-16-21 08:27 AM - Post#2827192
    In response to Che94
Honest advice? Don't use them. They're OK for a temporary repair but are not dependable as a permanent fix. Speaking from experience.
If you *must* use one for whatever reason, I understand, though I don't think there is any set torque figure as the size hole one might put the plug in can vary. I'd say once it feels snug and can withstand a pressure test up to 16psi or so without leaking, you're good.
Keep an eye on it once the weather turns colder as it will shrink. That's when the ones I fought with began leaking. I eventually replaced with a proper metal plug.
Che94
Reg: 04-04-21
09-16-21 10:30 AM - Post#2827197
    In response to someotherguy
Yeah, I saw plenty of negative comments about the rubber units. To the best of my memory, this is the 4th plug replaced in the old truck and I paid a mechanic to do the first 3, one of which was also rubber.
He told me he used it due to lack of accessibility (I couldn't fault him for that) but it has been in place a long time, with no issues. I was going to try a metal one but NAPA had nothing close to the size and I'm not sure what size it would take...
But I'm confident I tightened this one way beyond 15 psi limits...
Thanks...
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
09-17-21 06:48 PM - Post#2827290
I put one in a Ford 4.6? In a Crown Civ. It was either that or pull the motor.
I really dont have any extended history on it.
I had a '76 Pu w.a swapped in 305. I had it for awhile before I saw the plug. After that, I put 10 yrs or so on it.
Execution time: 0.164 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:54 PM
