Username Post: 63 Restoration question        (Topic#366410)
Factory59
Loc: Langley, BC, Canada
Reg: 11-16-06
09-15-21 09:50 AM - Post#2827132
I was wondering if anyone has any advice on how to replicate or clean cast parts back to a freshly cast look ? Specifically for suspension parts that were not painted from factory.
Iam not really interested in painting it, I would much rather just get it cleaned somehow and satin clear it to maintain the OE appearance.
Any ideas besides sanblasting ?
59 impala 2dr sport coupe
60 impala convertible
63 impala 2dr ht
55Brodie
Loc: Little River, SC
Reg: 12-26-15
09-15-21 11:06 AM - Post#2827134
    In response to Factory59
https://en.wikipedia.org/wiki/Dry-ice_blasting
junky
Loc: Northeast CT
Reg: 06-27-10
09-16-21 02:58 AM - Post#2827173
I know that you said that you don't want to paint them, but the cast iron paint by Bill Hirsch keeps that cast iron look without rusting. Once it is painted, no one could tell the difference between the cast part that was blasted and the painted part without rust on it.
Mercedes
Reg: 07-09-18
09-16-21 04:17 AM - Post#2827179
Any exposed metal (steel or iron) will react to moisture in the atmosphere and rust. The only way to prevent it is to apply a coating. I agree with the cast paint which looks like natural but does give the coating.
Factory59
Reg: 11-16-06
09-16-21 10:01 PM - Post#2827241
    In response to junky
Appreciate your response, I was thinking if there was a process to restore the cast metal back to new that i would then satin clear coat the cast part to stop any further rust.
May have to resort to paint but holding out some hope haha
63 impala 2dr ht
junky
Loc: Northeast CT
Reg: 06-27-10
09-18-21 02:51 AM - Post#2827295
You could try blasting with walnut shells, as they are the least abrasive, and see what it looks like. If you like the look, then clear coat it with a satin clear coat, but be aware, that the clear coat might peel away. If you don't like the look, you can always go back to the cast iron paint method. The cast iron paint spray is extremely good, and it doesn't look painted. Whether it be cast iron paint or clear coating, it is still painted!
grechevy
grechevy
Loc: delaware
Reg: 01-25-09
09-18-21 10:49 AM - Post#2827314
have restored 3 cars all suspension parts,bumper brackets,ect,derusted in electrolys tank ?.works perfect,just be sure to coat with something immeadiately after removing from tank and air drying.
Factory59
Reg: 11-16-06
09-19-21 08:07 AM - Post#2827377
    In response to grechevy
Thanks guyys for the suggestions, I will look into the cast paint and try the walnut shells.
What would you guys suggest for things like exhaust manifolds and brake drums ?
Thnaks in advance
63 impala 2dr ht
junky
Loc: Northeast CT
Reg: 06-27-10
09-20-21 06:23 PM - Post#2827550
Cast iron paint on the exhaust manifolds and brake drums were usually painted black. Bill Hirsch makes a high temperature black paint that comes in a spray can that works well on brake drums. Blast, wipe down with enamyl reducer to remove residue, and then spray.
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
09-22-21 10:21 AM - Post#2827694
  • junky Said:
.....Whether it be cast iron paint or clear coating, it is still painted!
Bingo! Clear coat is just clear paint.
For exhaust manifolds --> I suggest a cast-look ceramic coating. It should last for years.
I blasted my manifolds and painted them with VHT Cast Iron manifold high temp paint in 2015. Rust spots are starting to form, so I need to go back and touch them up.
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
09-23-21 01:32 AM - Post#2827745
    In response to BigDogSS
I went ceramic, tried several other coatings and all bled through over time. No issues with ceramic after 5 years.
Member #2194
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
09-23-21 05:52 AM - Post#2827765
    In response to DonSSDD
I did the ceramic coating as well. Eight years later, they are still in perfect condition. I suppose it has that 'over restored' look, but I like it.
- Dave
1964 Impala 4-door sedan
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
09-23-21 07:44 AM - Post#2827776
    In response to dcairns
Hi Dave, where did you get your exhaust manifolds coated?
Edited by BigDogSS on 09-23-21 07:45 AM. Reason for edit: No reason given.
327
Loc: Ontario , Canada
Reg: 02-09-21
09-23-21 01:50 PM - Post#2827812
kingkreeton
kingkreeton
Loc: Nashville TN
Reg: 04-15-11
09-24-21 08:56 AM - Post#2827863
Looks great.
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Factory59
Reg: 11-16-06
09-24-21 08:00 PM - Post#2827903
63 impala 2dr ht
Factory59
Reg: 11-16-06
09-24-21 08:02 PM - Post#2827904
That looks really nice, i like the look of ceramic coating and the fact that it holds up over time
63 impala 2dr ht
Factory59
Reg: 11-16-06
09-24-21 08:06 PM - Post#2827905
Thanks evryone, Iam in the process of restoring the frame and the suspension. Would it be correct in assuming that all the cast parts left unpainted front the factory ? I was going to powdercoat everything semigloss black except the cast parts ? any guidance on what is considered correct would be greatly appreciated !
63 impala 2dr ht
Factory59
Reg: 11-16-06
10-04-21 11:14 AM - Post#2828487
Do you have any suggestion on which brand of cast paint you liked the best ?
Thanks in advance !
63 impala 2dr ht
Execution time: 0.096 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:28 AM
