Username Post: '49 vs. '50 Parking Light Pods        (Topic#366408)
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
09-15-21 06:53 AM - Post#2827127
I shared this on Facebook...why not here also? The '49 assembly did not protrude from the grille as far as the 1950 did. Even though the '49 lens is taller, once inserted in the '49 bezel, it and the '50 lens, protrude the same distance from each bezel. The lenses are not interchangeable without some seating issues.
Attachment: 1949_vs_1950_Parking_Lamp_Parts.jpg (242.93 KB) 8 View(s)
1951 Fleetline Preservation
1950belair
Reg: 07-24-21
09-15-21 03:50 PM - Post#2827156
    In response to RAM_51
Can the entire bezel & lense from a '49 be swapped into a '50 grill? Meaning... are they the same diameter?
I need them, but I have a '50 and have a lead on '49 parking light pods with lenses.
Thanks,
-Phil
Edited by 1950belair on 09-15-21 03:51 PM. Reason for edit: No reason given.
RAM_51
RAM_51
Reg: 12-28-02
09-15-21 05:30 PM - Post#2827165
    In response to 1950belair
I wasn't going to rest until I got this question answered. The short answer is YES, it does fit and is a direct bolt in. One thing to note, the mounting studs are slightly off center so attention must be paid when they are installed. They must be rotated in the correct orientation for each side. The problem I see is with the fitment to the larger scalloped molding that is below the bezel on the 1950 grille...perhaps one of the reasons the bezel was elongated. A rather significant gap is formed between the bezel and the molding that is somewhat unsightly.
Attachment: 1949_Parking_Light_Pod_in_a_1950_Grille.jpeg (2.91 MB) 7 View(s)
1950belair
Reg: 07-24-21
09-16-21 06:38 PM - Post#2827232
Thanks for the follow-up. I will have to drag mine out to swap meets to make sure in case I find some.
Execution time: 0.463 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:03 PM
