Username Post: bell housing        (Topic#366394)
firecars
Reg: 09-13-21
09-13-21 01:03 PM - Post#2827029
I'd like to put a Chevy 250 engine (out of a 1969 nova)in my 48 Chevy car, is there a bell housing that will allow me to use the newer engine and old transmission and drive train?
I assume it has to be a 2 piece bell housing to secure transmission to it.
thanks Firecars
Broo102
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
09-14-21 08:02 AM - Post#2827069
    In response to firecars
I believe any tri 5 bell will work, however, they have "ears" in them that probably will contact part of the trans tunnel. I had to cut the ears off for my V8 install. Using a pre 55 bell might also fit since they were all from 6 cyl. motors.
Make a paper pattern of the back of your engine by tracing or by simply pushing the paper on to the back ridge of the block. Youll get a good impression that way to match up to any potential bell that you think might fit.
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
09-17-21 05:42 AM - Post#2827252
i have not seen a bell housing that will fit a 250 and also fit the small bolt pattern on the old style 3 speed.
Broo102
Broo102
Reg: 09-30-14
09-19-21 04:06 PM - Post#2827431
    In response to cbmkr56
I recall that is correct, most make a bracket flange, a flat piece of stock with the hole pattern of the bell and the trans
Ive seen it done, not hard to create
Thanks!
Bru
John 3:16
Execution time: 0.101 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:26 PM
