Username Post: 65 imp drive shaft        (Topic#366385)
995jim
"5th Year" Platinum Supporting Member
995jim
Loc: Ohio
Reg: 12-17-06
09-11-21 04:18 PM - Post#2826908
Hello, Is the vertical offset (angle) between drive shaft and output shaft of trans supposed to be equal and opposite at the rear pinion on rear end.
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
65_Impala
Reg: 12-29-02
09-11-21 07:19 PM - Post#2826914
    In response to 995jim
Yes, but the differential angle could be a bit more so that when the suspension loads up under full power it moves towards being the same.
995jim
995jim
Loc: Ohio
Reg: 12-17-06
09-12-21 04:19 AM - Post#2826921
    In response to 65_Impala
does the pinion rotate up when under acceleration?
Site Ambassador
09-12-21 06:43 AM - Post#2826928
More so on leaf spring cars, but yes the rear housing tries to rotate upward as you accelerate because the pinion gear is rotating and turning your differential ring gear. This makes the ring gear try to “climb” the pinion gear and since the ring gear is bolted to the differential and the differential is bolted to the rear end housing, the housing tries to rotate. The rear rotating upward is the reason traction bars were invented. They limit the amount the housing can rotate.
1957 Cameo Carrier
Execution time: 0.085 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:39 AM
