Danchuk
Username Post: recommended tire pressure        (Topic#366375)
Original57
Loc: Houston, TX
Reg: 04-07-09
09-10-21 08:27 PM - Post#2826870
On my 57 sedan, I have been running Coker re-manu BF Goodrich bias tires,7.50-14 at 30psi (prob. too high based on the tread wear) for years. The 57 green passenger car shop manual calls for 22 psi cold and 25 psi warm on those old bias 4 ply tires.
I just replaced them with 4 modern 205/75 R14 radials that have a max. inflation rating of 51 psi.
(a) is there an educated guess or scientific formula to decide what inflation on the modern radials? OR (b) request opinions or input.
09-11-21 05:31 AM - Post#2826876
    In response to Original57
51 is the maximum loaded pressure. 32-35 would suitable.
55MAS
Loc: North Coast, USA
Reg: 12-19-01
09-11-21 05:38 AM - Post#2826877
Everyone has a recommendation.
Right or wrong for my old cars running modern tires I run pressures that feel good and promote even tire wear. Generally this is lower than the tire label. It the tire pressure is too high you will feel it at the steering wheel. If you hit a pot hole or other you will know when the pressure is too high. If the pressure is too high the thread will wear in the middle and less at the edges. If the pressure is too low the thread will wear at the edges and less in the middle. You may start with a pressure recommended by others and watch my comments above and adjust to suit. Good luck.
55 Shaker
Loc: north central IL.
Reg: 03-13-06
09-11-21 07:00 AM - Post#2826880
I run all my radials at 35 PSI.
Original57
Loc: Houston, TX
Reg: 04-07-09
09-12-21 06:00 PM - Post#2826962
    In response to 55 Shaker
Thanks, all...
Mercedes
Reg: 07-09-18
09-13-21 03:12 PM - Post#2827033
Radial tires have a built in flat plane that they ride on, thus, the radial belt. If you look at a tire inflated to 25 lbs vs 45 lbs, you will see that the tread is flat against the road. The higher pressure makes the tire stiffer and less sidewall movement.
I agree that 35 is a good number.
addspeed
Reg: 08-11-21
09-13-21 04:26 PM - Post#2827037
I usually rely on the sticker located at the driver's door for an accurate PSI. You can see it on the car manual as well.
Mercedes
Reg: 07-09-18
09-14-21 09:16 AM - Post#2827070
    In response to addspeed
The sticker will show the recommended tire pressure, however, the sticker assumes that you have the tires at the time of the manufacture.
Radials were not available then.
55MAS
Reg: 12-19-01
09-14-21 09:48 AM - Post#2827073
    In response to Mercedes
Nor was the door sticker.
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
09-15-21 06:22 AM - Post#2827126
If were me I'd call Coker tire and ask them what tire pressure they commend for your tire.
No one knows better than the tire manufacture what is the correct pressure.
Remember,I'm not always right. But I'M never WRONG !
Member #409
09-15-21 04:46 PM - Post#2827160
    In response to pauldian
Most passenger car radials these days are supposed to run about 35 psi. A passenger car radial that's supposed to run at 50 psi would be pretty unusual. It wouldn't be uncommon though for a truck tire that had a higher load rating.
Mercedes
Reg: 07-09-18
09-16-21 08:26 AM - Post#2827191
    In response to Rick_L
On my Mercedes vehicles, the tire card calls for increased tire pressures if sustained speeds above 100 MPH are expected.
Not sure that it goes above 50 PSI, but you add more pressure.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-16-21 09:12 AM - Post#2827194
Here's some more irrelevant minutiae:
Bugatti Chiron w/top speed of 273mph has recommended tire pressure of 41 psi.
That (and anything Mercedes) is useless info for a '57 Chevy with P205/75R x 14 tires (the topic of the original question).
Original57; cold pressure of approx 35 PSI should keep the radials' sidewalls from flexing too much for your suspension (designed for bias ply tires). That's what I run on my '63 Impala's radials.
Hope that is helpful.
Pete
pauldian
pauldian
Reg: 05-14-09
09-16-21 11:46 AM - Post#2827200
    In response to japete92
https://tirepressure.com/p205-70r14-tire-press ure
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-16-21 01:40 PM - Post#2827206
  • pauldian Said:
Not sure why you are toe tapping at me. I do not see anything on the site that contradicts my recommendation of approx 35 psi. Also, I don't see any reason to expect the folks who assembled that data to know anything about tires they don not sell (bias ply for a '57 Chevy).
I stand by my recommendation (for this poster's question) of approx 35 cold psi. But there is no one 'correct number' for tires pressures for modern tires installed on old classic vehicles not designed for them; too many variables.
The '57 Chevy was designed for the stiffer sidewalls of the bias ply tires of the day. Adding more PSI (over the 22 cold psi for the '57 bias ply tires) helps reduce the flex of the radial and better replicate the bias tire.
Use whatever you like.
Pete
TAT_2
Site Ambassador - Member #26 - "20th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
09-16-21 04:07 PM - Post#2827216
18 WHEELS & A DOZEN DONUTS.
105 LBS IN EACH.
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANNIV- RUBY RED- LT1/6-SPD/RAG TOP
QUOTE FROM HELEN
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
09-17-21 05:09 AM - Post#2827249
    In response to TAT_2
Don't forget the coffee, and 'oldies' on the radio
Pete
pauldian
pauldian
Reg: 05-14-09
09-17-21 06:30 AM - Post#2827254
65 Impala BV
Loc: Willow Springs, IL
Reg: 10-12-20
09-22-21 04:55 AM - Post#2827674
The switch to radials was a definite good call. You'll enjoy all the benefits of a modern tire including improved ride quality, longevity and traction. My rule of thumb for heavier cars such as yours is a 0.8 multiplier to the max pressure rating of the radial tires and do this when they're hot. That way that's the highest pressure they will see. You'll get great, even wear, traction with no doming or cupping. So 0.8 x 51psi = 40.8 psi. You could round down to 40 and be fine. Good luck and enjoy your ride.
Thanks,
1965 Sierra Tan Impala SS 2D Coupe, LS3, BTR Stage 3 Cam, T56, 4.11s, 8.2" 10 Bolt
Brian
83_Burbin
Loc: Neenah, Wisconsin
Reg: 04-28-03
09-22-21 07:37 AM - Post#2827681
"Calling Coker Tire" might get you an answer. Considering todays automated voice mail technology though, I would kind of doubt it. We purchased a set of Coopers for our current vehicle a few months back (Not a Chev, we won't go there ...) anyway, back to the subject at hand, ... I had the same issue ... The tires are rated at 51 PSI. The door jamb sticker says 35 PSI. The tire shops paperwork said they were inflated to 35 PSI. So, I contacted Cooper by email (a "Contact us" link). Their reply was to go by the vehicles recommended pressure. Given that, I would definitely go by the majority of the memberships recommendation as they have probably gone through the transition themselves. Run them at 35 PSI for a while and keep an eye on the tread wear.
Old Chevies Never Die, They Just Rust Away .... used to believe this to be true but ... my S-10 died while rusting away!
'01 Coleman Santa Fe Pop-up camper
'07 Ford Freestyle Limited
jadatis
Reg: 02-10-15
09-22-21 09:06 AM - Post#2827689
I am able to calculate it for you.
Got hold of the official european formula end 2007 and went running with it
Need your GAWR's , GVWR, but better real axle loads in your use. Succes with dermining that, the most tricky part in it all.
Then also max speed youbwont go over for even a minute.
And tire-specifications, maxload and loadrange to determine the reference-pressure.
Radial tires need higher pressure then diagonal.
But if oversised tires, probably in the 20tees range.
Edited by jadatis on 09-22-21 09:07 AM. Reason for edit: No reason given.
jadatis
Reg: 02-10-15
09-22-21 01:52 PM - Post#2827711
  • pauldian Said:
Followed the link and checked the calculation.
They calculate for P-tires standard load with the old formula that results in lower pressure for the load, or higher loadcapacity for the pressure.
In 2006 TRA stepped over to the calculation of ETRTO, wich leads to better result.
The 26 psi in their list gives 1235 lbs loadcapacity. Calculated with the European formula( and after 2006 also American for P-tires), gives for 26 psi 1130 lbs loadcapacity.
Execution time: 0.133 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:57 PM
