Username Post: Saginaw gasket set?        (Topic#366364)
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
09-09-21 02:21 PM - Post#2826793
I cannot find a gasket set for this Saginaw 3 speed overdrive trans. 3 & 4 speed Saginaw's are the same, ODs have 1 extra gasket and several extra seals.
also need to know if the rear main shaft bearing is the same in the OD's as in a straight 3 speed
no luck NAPA or autozone. also no luck at several trans places on the search engine and ebay.
any help?
thanks Rod in AZ
62sedan
Loc: Above the red Texas dirt
Reg: 08-12-02
09-10-21 06:22 AM - Post#2826836
    In response to rod
Rod . . . I found this gasket set. It may be what you're looking for(?) https://www.ebay.com/itm/351173274675?hash =item51c...
As for the seals - - - are they something you can remove from your trans unit and possibly find a supplier that would be willing to help you match them?? Just a thought. Good luck in this quest and keep us informed on the progress.
Chuck
Edited by 62sedan on 09-10-21 06:23 AM. Reason for edit: No reason given.
Mercedes
Reg: 07-09-18
09-10-21 01:45 PM - Post#2826847
    In response to rod
I cannot imagine the input or output shaft seals being unique. They probably have the same seal a late model vehicle has.
The other gaskets may be hard to find. A bit of black silicone RTV smeared by finger to not be oozing out everywhere will outlast a gasket.
Execution time: 0.103 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:12 PM
