Username Post: Oil Pump Priming Tool        (Topic#366342)
PeteVS
PeteVS
Loc: 07932
Reg: 01-28-17
09-07-21 07:30 AM - Post#2826676
Does anyone make an oil pump priming tool with a flexible drive? My project car (not Corvette but it does have a SBC) has the distributor set back into the firewall and I can't get a straight shot into the hole. Thanks for any help here!
Edited by PeteVS on 09-07-21 07:31 AM. Reason for edit: No reason given.
Mercedes
Reg: 07-09-18
09-07-21 09:00 AM - Post#2826678
    In response to PeteVS
I've not seen a flexible tool and not sure how effective it would be. The amount of torque that is applied to prime the oil pump would likely bind up a flexible tool.
TAT_2
Site Ambassador - Member #26 - "20th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
09-07-21 01:19 PM - Post#2826687
DONT KNOW HOW MUCH ROOM U HAVE BUT A 90 DEG DRILL MIGHT WORK.
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANNIV- RUBY RED- LT1/6-SPD/RAG TOP
QUOTE FROM HELEN
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
09-12-21 05:39 PM - Post#2826960
    In response to TAT_2
Execution time: 0.143 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:15 PM
