Username Post: Electric Drain        (Topic#366288)
DucatiRod
Loc: Maine
Reg: 12-31-20
08-31-21 02:05 PM - Post#2826334
I posted this under Trucks '19 thru '59 but got no answer, so hope to get one here!
When I got my '54 3600 it already had 12 Volts and a one wire alternator. They had wired it directly to the junction at the starter, and doing so bypassed the amp meter. I rewired it using the original diagram and just bypassed the voltage regulator in a logical way, but now have an electric drain, but an amp meter that works! My question, before spending hours figuring this out, is there a trick to get this right (like a diode or something) This truck has the most difficult dash to work behind, and I've been behind many~
drummertom
Loc: Reidsville, NC
Reg: 09-03-06
09-01-21 06:01 AM - Post#2826372
    In response to DucatiRod
Could you not just add a volt gauge instead of the amp meter? It doesn't go in in series, so IMO it is easier to wire.
www.picturetrail.com/drummertom
"Well my time went so quickly. I went lickety spickley out to my ol' 55"
09-05-21 11:32 AM - Post#2826574
did you pinpoint where the drain is coming from?
DucatiRod
Loc: Maine
Reg: 12-31-20
09-05-21 12:09 PM - Post#2826579
    In response to bobb
Yes, I proved it yesterday, and it is the alternator. I put the volt meter between the + cable and the + battery terminal. With the alt. hooked up I read 12 volt, if I disconnect the alt. the voltage drops to zero.
Being I'm installing a big electric cooling fan, I've ordered a 100 amp relay to install between the alt. and the first connection after the alt. The magnet in the relay will be energized by the key, ignition is via a Magneto, so the key doesn't have much to do anyway.
I hope this ends the electric issues~
65_Impala
Reg: 12-29-02
09-07-21 04:12 PM - Post#2826700
Alternator still wired as a 1-wire or you reconnected the other wires?
If it is a 1-wire connection still then it has an internal issue. Fix that instead of adding more parts to mask it.
09-07-21 09:24 PM - Post#2826726
it wont take much of an amp draw to get a 12 volt reading. countryboy amp gauge would be a light bulb with a known amp rating. i was thinking of suggesting a relay but your a step ahead of me there. a well placed relay can sometimes cure a migraine headache, or a huge cost.
65_Impala
Reg: 12-29-02
09-08-21 12:59 PM - Post#2826745
    In response to bobb
Good point about the voltmeter measuring voltage with almost any load connected, even a load that is not large enough to be considered an abnormal battery drain. Should use an automotive light bulb or use the meter in current mode and measure the current.
Execution time: 0.087 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:44 AM
