Username Post: Need Mechanical help/ Info on 1969 307 - Power to points but no spark        (Topic#366263)
Dennis1965
Loc: Washington
Reg: 08-28-21
08-28-21 09:06 PM - Post#2826175
First, Hi to every one. I have a 1968 Slickcraft Boat with a Chevy 307 engine. I bought the boat 2 weeks ago and it had not ran in 15 years. I got her up and running the following day and the motor ran super smooth and then after 15 minutes, it fell on its face and just stopped. I ran a voltage test and have to the resistor, power at the coil, and power to the points. I went as far as buying a new set of points and condenser and still have zero spark when the points open up. I went as far as installing a electronic pointless setup in the distributor and I am still having the same issue. The distributor is a Mallory Model YL Type 520 AV. I understand that this is a boat, how ever the information and or help that I need is Chevy related and that is why I am on this sight. Can any one give me some pointers or has any one had this issue before? Help Help Help. Thank you!
rcr3
Site Ambassador -"18th Year" Silver Supporting Member
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
08-29-21 03:58 AM - Post#2826184
    In response to Dennis1965
Post your Question in the performance forum,farther down the page.
Welcome aboard!
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'73 Nova pro-street project
'17 Chevy Trax LT
08-29-21 04:39 PM - Post#2826228
with the electronics you need to delete the resistor. do you have 12 volts at the coil and distributor when cranking?
IgnitionMan
Reg: 04-15-05
08-31-21 04:45 PM - Post#2826339
Mallory uses a single resistor for points, and two resistors for one of their Uni-Lite systems, the stock one from switch to coil positive, then, a MOPAR early .60 ohm resistor from coil positive to Mallory module input wire.
"Boots" Mallory used a lot of MOPAR parts in his setups, but the Uni-Lite was the best electronic system. There is also a magnetic trigger system that needs the stock single resistor, but it is a real problem prone system.
Engine to battery ground is essential, not battery to whatever to engine.
Algoma56
Reg: 03-14-05
09-04-21 06:51 AM - Post#2826511
    In response to IgnitionMan
As above, check ground, good ground, engine to battery.
Execution time: 0.087 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:14 PM
