Username Post: HEI stamped number identification        (Topic#366244)
Pmac
Reg: 11-13-20
08-27-21 06:33 AM - Post#2826077
I am trying to identify a HEI distributor with a stamped number 1103357 followed by 8C16 - I reckon the last four numbers are a date code, but have found conflicting interpretations for the numeric values but the C likely means March - the ICM number is 990 8B23 and the Vac can is stamped 57 and a stenciled number 242, any help in a application or a site would be great, so far all the sites have numbers that skip the '3357' part.
Mercedes
Reg: 07-09-18
08-29-21 07:10 AM - Post#2826199
    In response to Pmac
Try this site. The part number is obsolete but it appears to work in 1978 model year 5.0 Liter V8 engines of General Motors.
https://www.yoyopart.com/oem/12019432/casting- 1103...
Pmac
Reg: 11-13-20
10-06-21 03:53 AM - Post#2828602
    In response to Mercedes
Thanks! I have not seen this page before - the Delco-Remy site describes this P/N as CCW(!) application - I will continue my search, and I am grateful for the help.
Mercedes
Reg: 07-09-18
10-10-21 12:28 PM - Post#2828920
    In response to Pmac
There is nothing magic with the part, other than the plug for the power to the HEI and the weights on the centrifugal advance.
Line up the same era small block distributor and be done with it.
Execution time: 0.105 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:57 AM
