Username Post: Steering wheel        (Topic#366056)
Hiosilver
Reg: 03-22-20
08-09-21 09:35 AM - Post#2824797
I have a 1986 Silverado with a loose steering wheel, I’m wondering if it would be easier to change it out with a aftermarket column or repair the old one. Any thoughts will be appreciated
Ron
Edited by Tony on 08-09-21 11:12 AM. Reason for edit: Moved post to correct forum
08-09-21 02:48 PM - Post#2824823
    In response to Hiosilver
My truck has a loose column too. It was tight for a long time. I didn't remove the screws and use locktite on them. You can remove the steering wheel, plate, springs, and turn signal switch. I crafted my own "U" tool to press down the plate. Once all the parts are removed, you can take out one screw at a time. Use red locktite and put them back in. It's not hard. It can be complicated if you have never removed the internal parts. I'll look for a good write up with pictures.
'08 GMC Acadia 3.6L SLE
Execution time: 0.091 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:09 AM
