Username Post: can I swap 2006 2500 4x4 suspension and drivetrain to 2006 1500 4x4        (Topic#366049)
buck24u
Reg: 08-08-21
08-08-21 07:51 PM - Post#2824762
Hello I have a wrecked 2006 GMC 2500 4x4 that had a 6.0 and want to use suspension and drivetrain as far as trans,transfer case and differentials over to my 1500 chevy 4x4 with 5.3 and I know your gonna say just swap frames but what's easiest and less work I'm getting a new 5.3 with 460hp and don't want to use the running gear I have now won't handle it and actually I just want to change front and rear differentials and transfer (case cause it matches differential) and figure the suspension on 1500 wont match up to 2500 front and rear end
0
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
08-11-21 09:44 PM - Post#2824973
    In response to buck24u
Howdy and welcome!
Sounds like you’re not afraid of a little work. Yes you can, but there are some things that may not be a direct bolt on swap.
The frames themselves are also different. The 2500 frame is much stronger than the 1500. You can see that in the cross members from the transfer case back.
I’m reasonably certain someone here has done what you’re wanting to do.
Greg
‘01 Silverado 2500HD 8.1/Allison 1000 Xcab/LB
'00 Explorer XLT 4.0 SOHC V6 Auto
'95 K1500 Z71 EC Short Step 5.7L+0.040/NV3500 SOLD
buck24u
Reg: 08-08-21
08-18-21 08:34 PM - Post#2825522
    In response to CowboyTrukr
Thanks and no im not afraid of probobly a lot of work but i dont mind swapping frames if that would be easiest as long as running ghear will work or bolt up to my motor and trans i dont have teh tranny from 2500 but do have transfer case so ill have to swap body motor and tranny to 2500 and you say some things wont bolt up directly can you tell me what maybe steering linkage will i hope and well i am not sure any info will be greatly appreciated
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
08-18-21 09:09 PM - Post#2825524
The engine and transmission/xfer case will bolt right in. The steering bolts right in as well.
Greg
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
08-19-21 04:00 PM - Post#2825560
Agreed. If you want the 3/4 ton running gear, you'll have to have a 3/4 ton frame. I don't believe any of the running gear will interchange from a 1500 to a 2500. It may not be too hard to fabricate brackets to make the rear differential fit, but I don't think there's a way to get the front differential to fit.
I used parts from a 2004 GMC 1500 to repair a 2007 GMC 2500 HD about 12 years ago. I used all sheet metal other than the cab from the 1500 for the repair. Both were extended cab short beds, and all sheet metal was the same. The main difference I can remember is that the 2500 had a grill with a black spacer to fill the area between the grill and bumper to account for the taller frame. The grill was actually different, even though at first glance it looked like the spacer was a different part. The bumpers were the same.
buck24u
Reg: 08-08-21
08-25-21 07:56 AM - Post#2825937
    In response to jktucker92
I thsnk you sll thats all i wanted to hear before i dived in and as long as bodies will swap and i can bolt my motor snd tranny up to the existing transfer cases then it is a go for me i just didnt want to get halfway into it and find out i have some serious modifications that will have to be done im ok with minor and glad for the advise ill ket you know how it works out in a couple months maybe as i have to do this in my spare tome which isnt much. Thanks again!
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
08-25-21 09:00 PM - Post#2825988
Pictures!!!
Greg
Execution time: 0.101 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:38 PM
