Username Post: Power brake kit        (Topic#366019)
Eddy_Finn
Eddy_Finn
Loc: Finland
Reg: 07-19-21
08-04-21 10:09 PM - Post#2824524
Ordered a power brake kit for my -62 Biscayne from Summit Racing.
https://www.summitracing.com/parts/sum-bk1515
Any comments about quality and compatibility or bolt on experiences?
Miss or a hit?
Thanks advance for your sincere comments.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
08-05-21 05:42 AM - Post#2824535
    In response to Eddy_Finn
I do not know anything about the kit you bought. But is does recommend 15" wheels. That's likely 'required'. But, as I said, I've no specific knowledge of the 'kit'.
Be prepared to change wheels and tires. Also, the wheel covers for a 14" wheel will not work with 15's.
Did you intend to also convert to front discs?
Power brakes can be 'added' to the drums w/o changing to front discs. If accomplished as GM did it, no 'other' changes are required.
Vendors sell front disc 'kits' for 14" wheels but they are based on Camero/Chevelle vehicle parts/weights (smaller rotors, for example). When GM went with front discs on the full size cars, the also changed to 15" wheels.
Just info.
Pete
Edited by japete92 on 08-05-21 05:51 AM. Reason for edit: No reason given.
Eddy_Finn
Eddy_Finn
Loc: Finland
Reg: 07-19-21
08-06-21 03:46 AM - Post#2824610
    In response to japete92
This is something i did not notice while ordering... :crazy :
More money going with this stupid mistake of mine, not reading everything three times.
I was
This might be my savior for not buying new set of wheels!
BUT, i'm investigating reasonable priced wire spoke wheels 15", looks pretty expensive especially for shipping & handling costs.
There are used sets available, but 99% of ads says "pick up, no shipping". Ebay and Craigslist sellers do not put extra effort sending stuff over seas... Unfortunately
ragtp66
Reg: 12-09-07
08-07-21 12:49 PM - Post#2824692
Autocityclassics.com makes a disc brake kit that will work with stock 14" wheels if you want to keep your stock wheel combination.
Toys:
1987 Sea Ray Pachanga 22
08-08-21 10:14 AM - Post#2824733
sorry that you did not ask before ordering.
Execution time: 0.071 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:12 AM
