Username Post: th400 trans        (Topic#366016)
995jim
"5th Year" Platinum Supporting Member
995jim
Loc: Ohio
Reg: 12-17-06
08-04-21 04:24 PM - Post#2824501
Hi, Does the th400 trans have a standard quantity of fluid to fill with 1 qt already in torque converter. I want to start a new engine in my resto but dont have driveshaft yet.I would just leave it in park. Just waiting till car has full weight before measuring shaft length
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
Member #409
08-04-21 04:54 PM - Post#2824505
    In response to 995jim
Fill quantity will vary with the actual torque converter used and also how much fluid is in the cooler and lines. It's going to be 10-13 quarts.
Thing is, you can't get all the fluid in a new start up until you start it and move the gear selector through all positions. The usual deal is you fill it to the dipstick mark, then start it and shut it off. Fill again to the dipstick mark, start it and move the shifter through all positions and fill again. Start it again and fill to the dipstick mark, this time while running.
If you don't have a driveshaft, stick a used driveshaft yoke in it for this exercise. Or just wait.
995jim
995jim
Loc: Ohio
Reg: 12-17-06
08-05-21 08:28 AM - Post#2824548
    In response to Rick_L
I have the yoke but will it free wheel while shifting and cause grinding during shifting?
Member #409
08-05-21 08:48 AM - Post#2824549
You said you were going to leave it in park?
995jim
995jim
Loc: Ohio
Reg: 12-17-06
08-05-21 12:44 PM - Post#2824559
I planned on leaving it in park just to start the engine and wondered if there would be any adverse affect to the trans without shifting through the selector to move trans oil around.
5Larry7
"18th Year" Gold Supporting Member
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
08-05-21 02:32 PM - Post#2824573
Were it me I would wait until the driveshaft is in place so you can shift it through the gears as per Rick L posted.
995jim
995jim
Loc: Ohio
Reg: 12-17-06
08-06-21 12:51 PM - Post#2824650
    In response to 5Larry7
ok. I will just load the seats, tailgate and bumper in for actual weight to get the shaft made due to mods with the car.
08-07-21 09:20 AM - Post#2824685
start it put it in gear and turn it off. then back to park or neutral.
Execution time: 0.142 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:33 PM
