Username Post: Fender skirts        (Topic#366005)
4oldcars
4oldcars
Loc: Little River, S C
Reg: 08-26-15
08-04-21 06:26 AM - Post#2824453
I sold my 53 and bought a 51. I don't know why. The 53 sure was nice and I wasn't gonna buy any more cars at my age. The skirts on the 51 don't fit as well as I would like them to. Does anyone know, are the skirts the same for 49 thru 52? Could I have the wrong ones?
1951 Styleline Deluxe 2 dr sedan
2000 Black Eldorado
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
08-04-21 06:56 AM - Post#2824457
    In response to 4oldcars
I assume '49 and '50 would match and the '51 and '52 would match. Only a guess on my part.
Dean50
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
08-04-21 07:02 AM - Post#2824458
Skirts are grouped as follows:
49-50 and 51 and 52 Station Wagon and Sedan Delivery (slight taper - about an inch - front to rear, there is a left and right skirt)
51-52 symmetrical and interchangeable left to right
53-54 symmetrical, not 100% sure if these are interchangeable but mostly because of attachment points (53-54 owners can chime in)
As an experiment, knowing that it would not fit properly, I put a 49-50 skirt into my 51 Fleetline. It took a little doing but I got it in there. This is the result:
Attachment: 1950_Skirt_in_1951_opening.jpeg (2.82 MB) 5 View(s)
1951 Fleetline Preservation
4oldcars
4oldcars
Reg: 08-26-15
08-04-21 11:54 AM - Post#2824480
    In response to RAM_51
This is what I have.
Attachment: IMG_0951.JPG (2.86 MB) 8 View(s)
2000 Black Eldorado
RAM_51
RAM_51
Reg: 12-28-02
08-04-21 12:00 PM - Post#2824482
I see you have your car listed as a DeLuxe. Is it actually a DeLuxe? Or maybe a Special that had skirts added later on?
To me, it just looks as though the rear bracket needs to up a hair.
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
08-04-21 06:36 PM - Post#2824517
'53 and '54 are the same but there is a left and a right. I believe all models across the board were the same however, I don't have any experience with the wagons.
RAM_51
RAM_51
Reg: 12-28-02
08-04-21 08:19 PM - Post#2824522
    In response to kool53
Okay thanks. And am I right in assuming there is a left and right because of the brackets and how they attach?
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
08-05-21 06:28 PM - Post#2824589
  • RAM_51 Said:
Yep, bracket towards the front
Airlifter
Airlifter
Reg: 06-07-15
08-06-21 03:38 AM - Post#2824608
I am glad that this post came along. It seems that I have two left side fender skirts. One skirt has the bracket at the rear and the other at the front.
I think that I could swap ends with the brackets on the offending fender skirt to make it right. I should be able to take good measurements and re-drill the holes and brad them in place.
Thanks, Pete
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
4oldcars
4oldcars
Reg: 08-26-15
08-06-21 06:23 AM - Post#2824627
    In response to Airlifter
Mine has then locking mechanism at the rear. Is this what is being referred to as brackets? Are mine on backwards?
2000 Black Eldorado
Airlifter
Airlifter
Reg: 06-07-15
08-06-21 07:14 AM - Post#2824630
The mounting bracket with the long slot is at the rear of the fender well. To me it is a lot easier to hook the fender skirt in there and lock it in on the front. But what do I know? I didn't even know I vhad two left side skirts.
RAM_51
RAM_51
Reg: 12-28-02
08-06-21 08:02 AM - Post#2824633
1951-1952 Fender skirts are exact "carbon copies" of one another. When installed, the loop latch is to the front on the left side, and to the rear on the right side. There was only one skirt made for the '51 and '52 model year and that one skirt was used on either side. The photo below is of the original skirts from my '51 Fleetline. They are exactly the same in every detail. The image below that is the hardware kit that was used when adding skirts to a Special. Note that all 4 brackets are identical and this is what is evident on my original Fleetline. They are exactly like what I used when I added skirts to my Special Business Coupe.
Attachment: 1951_Fleetline_Fender_Skirts.jpeg (4.37 MB) 3 View(s)
Attachment: 1951-2_Special_Fender_Skirt_Hardware_1.jpg (382.05 KB) 6 View(s)
Attachment: 1951_Chevrolet_Business_Coupe_Rear_Wheel_.jpg (1.49 MB) 1 View(s)
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
08-06-21 09:08 AM - Post#2824637
My'50 skirts are left and right hands and fit pretty snugly.
Attachment: 20210804_155659_HDR.jpg (1.05 MB) 4 View(s)
Dean50
4oldcars
4oldcars
Reg: 08-26-15
08-06-21 11:42 AM - Post#2824644
    In response to Dean50
When I had my 53 the locking mechanism was at the front on both, they fit well, and they were easy to remove/install. But that was a nice car. These are a nightmare. They don't even have the loop handle. I think I'll shop for a set of skirts. Anyone have a pair to sell? Thanks to all for your help. If I was younger I'd get smart, but at my age, I just bump along.
2000 Black Eldorado
Airlifter
Airlifter
Reg: 06-07-15
08-06-21 12:07 PM - Post#2824647
The mounting bracket with the long slot is at the rear of the fender well. To me it is a lot easier to hook the fender skirt. Should the hardware with the long slot be on end that hooks or the one that locks with the lever?
Edited by Airlifter on 08-06-21 12:08 PM. Reason for edit: No reason given.
RAM_51
RAM_51
Reg: 12-28-02
08-06-21 01:17 PM - Post#2824654
On the 1951 and 1952, the hardware is the same at all four locations. This is the way it is on my original 1951 Fleetline. The photos below are of the brackets on the left side of the car, but they are exactly the same on the right side. Although difficult to see, It is also what is detailed in the Accessory Installation Manual when installing fender skirts on a Special. Given what was included in the kit - see photo above in prior posting, it is how I installed the skirts on my Special coupe and they fit very well.
Attachment: 1951_Fleetline_Front_Fender_Skirt_Bracket.jpeg (2.73 MB) 4 View(s)
Attachment: 1951_Fleetline_Rear_Fender_Skirt_Bracket.jpeg (3.01 MB) 1 View(s)
Attachment: Skirts_Installed_on_Special_Model.jpeg (476.49 KB) 7 View(s)
Airlifter
Airlifter
Reg: 06-07-15
08-06-21 02:51 PM - Post#2824659
Thanks. I will try to find the proper hardware.
belairbob50
Loc: OH where rust never sleep...
Reg: 03-17-13
08-07-21 04:50 AM - Post#2824676
I have one skirt that was sold to me as a 1950. It is not. It looks a lot like the one RAM posted. I don't want to say it's NOS but it is pretty nice. There are staples holding the weather strip on. Send me a PM if you are interested. Thanks
[image]https://[/image]
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
08-08-21 03:58 PM - Post#2824751
Wow, Thanks RAM. I never knew that about the levers on the earlier models going opposite directions from side to side- learn something everyday I guess... Your post also points out something else I've always wondered. All my experience comes from the 53/54's and I always see the brackets offered as a set of four. That was always strange to me seeing as only two are required for 53/54, now I know why.
4oldcars
4oldcars
Reg: 08-26-15
08-10-21 06:27 AM - Post#2824868
Thanx to all that commented. I found a replacement pair of skirts. They are on their way. One question remains. Ram suggested that my car may not be a Deluxe but a Special that had skirts added. How would I tell if my car is a Deluxe or altered Special?
2000 Black Eldorado
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
08-10-21 07:46 AM - Post#2824874
Firewall tag
1952 Styleline Fourdoor, 62 235 Cast Iron Power-glide.
Six in a Row, makes Her go
RAM_51
RAM_51
Reg: 12-28-02
08-10-21 09:56 AM - Post#2824882
    In response to gcrkfrd
  • gcrkfrd Said:
Firewall tag
Following gcrkfrd's post, Style No. would tell the story on the cowl plate. 51-12XX would be a Special while a 51-10XX would be a DeLuxe. You can also determine it from the Serial Number on the "A" pillar. A "J" in the third place indicates a Special, while a "K" in the third place indicates a DeLuxe.
Just a thought after seeing your photo. Are you sure the attaching rod isn't bent and not pushing the skirt up further?
Execution time: 0.126 seconds.   Total Queries: 21   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:21 PM
