Username Post: transmission shift lever 48 Chevy Fleetline        (Topic#365995)
STOKER1948chevy
Loc: OHIO
Reg: 08-03-21
08-03-21 12:05 PM - Post#2824399
my car has no vacuum assist on the shifter, and the big lever with nut and bolt on top to tighten it on trans shaft is worn and rounded by years of use an being loose. the trans shaft has a key way in it but I don't know if the lever had a gripping tooth or was the lever made to tighten and hold the key at the same time . any ideas on how to tackle this is appreciated .
whiskey1954
whiskey1954
Loc: central north carolina
Reg: 12-07-08
08-03-21 03:36 PM - Post#2824412
    In response to STOKER1948chevy
let me welcome you to CHEVYTALK great forums someone here has an answer for you Im sure of that!
STOKER1948chevy
Loc: OHIO
Reg: 08-03-21
08-04-21 05:23 AM - Post#2824436
    In response to whiskey1954
thanks for the reply, think I found one at a bone yard ,they are sending it to me an we will see. I really just want to drive it some ,its been along time an since retiring took time to get it together.
Broo102
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
08-04-21 01:22 PM - Post#2824487
look for ChevGene on this web site. He would know
chevgene@msn.com
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Edited by Broo102 on 08-04-21 01:23 PM. Reason for edit: No reason given.
STOKER1948chevy
Loc: OHIO
Reg: 08-03-21
08-05-21 03:44 PM - Post#2824575
    In response to Broo102
Thanks I will look him up.
STOKER1948chevy
Loc: OHIO
Reg: 08-03-21
09-09-21 05:18 AM - Post#2826772
thought I'd tell all about my shift arm. I had one shipped up from Texas hoping it would do the trick ,well it was as worn out as the one I had so a buddy volunteered to weld new teeth on the old one an that worked. a little weld and a lot of filing got it done .and I learned a lot about these trannys. right now all is well an I have been driving some.
Execution time: 0.113 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:55 PM
