Username Post: gas gauge        (Topic#365950)
basstracker
Reg: 11-09-18
07-30-21 08:21 AM - Post#2824161
hello everyone, i ran out of gas and my gauge was showing between 1/4 an 1/2,.when i turn the switch off it stays pretty much the same. should the gauge go to empty with the switch off.thanks
junky
Loc: Northeast CT
Reg: 06-27-10
07-30-21 08:26 AM - Post#2824162
    In response to basstracker
My fuel gauge stops at random points, and is not the most accurate gauge, however, I can see to the bottom of my tank, since it is a station wagon, so when it is getting low, I can visually check how much fuel is left in the tank. I never let the tank go to empty, unless there is no place to get fuel. I just assume 10 miles per gallon, and fill the tank when the car travels 100 miles or so. If it got better fuel economy, I would drive it more often on longer trips.
basstracker
Reg: 11-09-18
07-31-21 04:53 PM - Post#2824222
    In response to junky
i pulled the sender wire off with the switch on and the gauge went to full. i grounded the sender wire and it went to just above 1/4 of a tank. does that mean the gauge is bad?
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
08-01-21 07:27 AM - Post#2824242
hHere is the manual section that gives the testing procedure. section 9-61
https://www.dropbox.com/sh/e6y4bdp4z7oagvr/AA BzzA6...
Edited by turbo38s10 on 08-01-21 07:28 AM. Reason for edit: No reason given.
Execution time: 0.125 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:18 PM
