Username Post: 1991 Suburban windshield wipers run slow        (Topic#365949)
tractordrivindan
tractordrivindan
Loc: Riverside county ,CA
Reg: 04-05-19
07-29-21 10:23 PM - Post#2824141
my wipers run slow at all speeds, a light rain is dangerous. any suggestions for my problem?
thanks
07-30-21 03:31 AM - Post#2824146
    In response to tractordrivindan
Does your model have constant power? I know mine does. I'm not sure if GM changed the power supply with a switch change. Clean the fuse contacts. Clean the wiper motor wire contact. Has the wiper motor ever been replaced?
'08 GMC Acadia 3.6L SLE
tractordrivindan
tractordrivindan
Reg: 04-05-19
07-30-21 04:45 PM - Post#2824181
still the stock one
07-30-21 05:28 PM - Post#2824182
A replacement is a good start. However, lubricating all the possible moving parts will help too. Alternators also put out low amps. Upgrading to a 110 amp or high alternator will help. My truck has a 165 amp Denali alternator. The high amps make a difference on windows and accessory use.
tractordrivindan
tractordrivindan
Reg: 04-05-19
07-30-21 05:53 PM - Post#2824184
I put a Mechman alternator on, it puts out 145 at idle and 178 at cruising. I also put 2 16" SPAL fans pulling 1918cfm with the a/c front and rear blowers on the voltage sits at 13.5 v my charge and ground wires are #2 welding cable. the voltage is right up there, I will clean and check the wiper motor connections and check voltage at those points also.
Edited by tractordrivindan on 07-30-21 05:55 PM. Reason for edit: No reason given.
Execution time: 0.12 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:25 PM
