Username Post: '63 327 choke heat tube question        (Topic#365946)
8683jb
Reg: 09-06-13
07-29-21 12:56 PM - Post#2824119
How does the clean air line attach to this end of the choke heat tube? The hole in the tube is .193". Is the clean air line 3/16" tubing that just slips inside this hole?
Edited by 8683jb on 07-29-21 01:24 PM. Reason for edit: No reason given.
Anonymous
07-29-21 10:52 PM - Post#2824143
    In response to 8683jb
Not sure if this helps, but give it a try. It looks like you have a piece of tube broke off in the manifold, but maybe I am not remembering things correctly.
http://www.chicagocorvette.net/diagram_view.php?d=...
Edited by Impalas4ever on 07-29-21 10:53 PM. Reason for edit: No reason given.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
07-30-21 02:17 AM - Post#2824145
    In response to Impalas4ever
This tube fits inside the exhaust manifold and the tube from the carb slides in the hole in the top of manifold. There are rubber lines running from the bottom tube to the carb, check the assembly manual for the complete setup, if you don’t have the assembly manual, get one.
Attachment: A04F1161-365B-4844-A00D-C58AF352971D.jpeg (15.66 KB) 13 View(s)
Member #2194
Edited by DonSSDD on 07-30-21 02:20 AM. Reason for edit: No reason given.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
07-30-21 06:11 AM - Post#2824154
I've attached a screen shot from the '63 Shop Manual. Between the diagram and the pic, you should have a good idea of the system's configuration.
Pete
Attachment: 327_v8_from__manual.png (122.21 KB) 38 View(s)
8683jb
Reg: 09-06-13
07-30-21 07:00 AM - Post#2824158
    In response to japete92
Thank you guys. Before now, the only pictures I've seen of the tube and its hose were showing them to the REAR of the center exhaust outlets. I've seen the tube advertised but I couldn't see how it would fit. Now it makes sense. I thought the tube in the manifold might've been broken off too, but seeing it in person, it's clearly a rolled end so maybe it's not in far enough. I'll check that out. I appreciate the help!
8683jb
Reg: 09-06-13
07-30-21 07:05 PM - Post#2824186
Thanks to your guys' help here, I've got it. I tried to buy the fresh air tube online, but all three places I tried to order from charged literally twice as much for the shipping than the cost of the part! I used a piece of scrap 1/4" brake line I had here and made one up. Again, I appreciate all the help.
Edited by 8683jb on 07-31-21 08:38 AM. Reason for edit: No reason given.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
07-31-21 03:00 PM - Post#2824217
There's no reason fabricated parts can't be made to do the job of supplying "clean air" (the terminology in the Shop Manual) from the carb, thru the manifold, to the choke (it's a closed system). "Clean air" from the carb keeps the choke from sticking due to 'dirt'.
Because it's a closed system, there can be no exhaust gas leaks; either 'out' of the manifold, or 'into' the closed 'clean air' system.
The '63 Shop Manual Supplement describes the system better than I can.
Pete
dcairns
dcairns
Loc: Orange CA
Reg: 11-07-03
08-01-21 04:00 PM - Post#2824262
This pic shows the tube inside the manifold. Disregard the upper manifold, that on had been modified to remove the tube for a different application.
- Dave
1964 Impala 4-door sedan
Execution time: 0.125 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:03 PM
